It is currently Sat Apr 18, 2015 1:52 am
 Post subject: Counter Strike max fps
PostPosted: Mon Sep 13, 2004 4:57 pm
i have a geforce 6800 gt and it wont go past 60 fps on counter strike which i find dissappointing i changed my max fps 100 in console but nothing has changed i need help also i tried changing quality to performance and nothing
PostPosted: Mon Sep 13, 2004 5:03 pm
King of All Voodoo2 Cards
Do you have V-Sync enabled and a 60Hz refresh rate?
PostPosted: Mon Sep 13, 2004 5:06 pm
v sync off and yea my fresh rate is at 60
PostPosted: Mon Sep 13, 2004 6:14 pm
I would say that might be the reason it won't go past 60
PostPosted: Tue Sep 14, 2004 6:42 am
yea i tired changing it nothing
PostPosted: Sat Sep 25, 2004 2:31 pm
i would reccomend downloading the newest drivers for your video card, secondly try changing your cl_updaterate to 101 and your cl_cmdrate to 101, you can also try downloading the cplcsgui2 from the cpl site, it has alot of modified settings that improve performance, set your fps_max to 100 instead of 100 this should improve things a bit i got about 10 fps more when i cranked it up all the way, you can also play around with your cl_update and cl_cmdrate settings a bit to improve your chop and choke. the effectiveness of these settings vary from server to server so typing net_graph 1 in console will show you and active display of what these settings are currently at. hope this helps a bit, if not.... iono buy your self a really big hammer and go to town.
- Your friend batman..... er, props
