It is currently Sat Mar 28, 2015 7:29 pm
 Post subject: Doom3 Problems and solutions
PostPosted: Wed Aug 04, 2004 11:54 am
Out of the box, I've only noticed 2 problems.
1. Surround Sound is not working on Audigy card.
To fix this you need to turn off "Syncronize with control panel" check in the Creative Mixer app. Then go to your Windows Sound setup and select correct setup in the speakers pulldown menu (5.1 for me). No need to reboot, even tho it asks you to...
2. Multiplayer.
Every time I get message "Server is full". Even on empty servers. Not sure if my firewall is causing the problem (I can play UT2004, etc. without any problem online). If anyone knows answer to #2 let me know :)
PostPosted: Wed Aug 04, 2004 11:58 am
Many people are hosting multiplayer on the system they are playing on so there isn't enough bandwidth i think.
On a side note...
Do you know what to do after you follow the fat guy with the electric lantern? I go up the ladder and then what do i do? The fat guy got killed right in front of the ladder... :?
PostPosted: Thu Aug 05, 2004 7:50 am
On a side note...
I think there's a ladder somwhere in this room which goes down... I don't remember but I found it after looking around for 1 min.
