It is currently Wed Jan 28, 2015 4:37 am
 Post subject: Doom III SMP Aware?
PostPosted: Tue Aug 03, 2004 5:01 pm
King of All Voodoo2 Cards
So was/is there any word if Doom 3 will take advantage of multiple processors?
PostPosted: Tue Aug 03, 2004 5:12 pm
if it does woot, i got dual xeons waiting
PostPosted: Tue Aug 03, 2004 5:34 pm
i would imagine so if quake 3 did back 4 years ago.
PostPosted: Tue Aug 03, 2004 5:37 pm
So would I, but does anyone know for sure?
PostPosted: Tue Aug 03, 2004 10:10 pm
Doom 3 is does NOT support SMP, Carmack prefers the elegant approach to single cpu's.
Quote:
http://www.gamespot.com/pc/action/doom3/printable_6103236.html
We haven't gone through all that decision-making yet. But I think for our next project, we'll probably take a PC-centric approach, given what John Carmack said at his programming keynote at the Game Developers Conference this past spring. He said he didn't really like the technical aspects of the [next] generation of consoles--in terms of Xbox 2 and PlayStation 3--with their multithread approach, dual GPUs, and dual processors. They don't have the simple, elegant approach of a single CPU and a single GPU. Given that's where John thinks you can do the most exciting things from a technology standpoint, I expect that's where he's going to go from a programming standpoint.
PostPosted: Wed Aug 04, 2004 9:57 am
ok, but i dont really care it doesnt affect me as i only have a single proc anyway.
PostPosted: Wed Aug 04, 2004 2:10 pm
I've read through this about three or four times and it sounds like the guy who wrote the article doesn't know either, because of the way he seems to be paraphrasing most of Carmack's keynote.
Using phrases such as "I expect..." means that the guy who wrote this article is speculating doesn't know for sure either.
Does anyone have a definite answer here and not just speculation and conjecture?
PostPosted: Thu Aug 05, 2004 6:04 pm
thats what i was thinking as well. it sounded like that was an old quote before the game was even done as well.
PostPosted: Thu Aug 05, 2004 11:36 pm
well i dunno if it does take adv of 2 cpus or not, i got 2, but i cant see how im supposed to compare it with other computers/ 3d cards
PostPosted: Fri Aug 06, 2004 4:27 am
Heh, you should probably check the source of the quote before you comment on the date, it was published on July 22. Not to mention that the quote is from Todd Hollenshead, ID's CEO.
PostPosted: Fri Aug 06, 2004 8:53 am
Run Doom III, hit alt-tab, open up the task manager and see if Doom III is using both CPUs.
PostPosted: Fri Aug 06, 2004 8:56 am
Despite the source of the quote, there's still no definite answer.
I'm going to see what they're saying over at 2cpu.com
PostPosted: Fri Aug 06, 2004 9:02 am
Ok here's what one of the options I found over at 2cpu:
I just picked up my copy last night and I did the following at the console:
set r_useSMP 1
I then did:
listcvars
and indeed it shows:
r_useSMP = "1"
Are you sure there is no SMP support? I have a dual Xeon 2.6ghz system and I ran timedemo demo1 five times with and without it enabled. Without it enabled my average was 43 fps. With it enabled the average was 50 fps. Seems to be working to me.
So it appears that it's no officially supported, but it is possible to enable, however the benefits aren't all that impressive.
PostPosted: Fri Aug 06, 2004 9:04 am
Solid as a rock
Solid as a rock
Would it have that same effect with HT cpu's
PostPosted: Fri Aug 06, 2004 1:28 pm
It looks like it supports SMP/HT out of the box.
Don't have gimp 2 installed yet on this machine. I'll post screen in a sec.
PostPosted: Fri Aug 06, 2004 1:37 pm
http://gallery.colby.dhs.org/shuttle75s/doom3smp
