It is currently Wed Jan 28, 2015 9:47 am
 Post subject: DOS emulator for old games?
PostPosted: Fri Jul 30, 2004 7:21 pm
Is there a good DOS emulator that can be used to run old DOS games (from the mid 90s) with sound? I use WinXP. Thanks.
PostPosted: Tue Aug 03, 2004 3:27 pm
King of All Voodoo2 Cards
Probably not.
I keep an old Pentium P24T Overdrive to play all the old DOS games because I never found any type of emulator that could allocate the resources properly for the sound to work and the game to run.
PostPosted: Wed Aug 04, 2004 12:47 pm
I used DOS box to get shadow warrior working in Win2k. I had to monkey with the settings a bunch to get it to go, but it worked. Check it out, maybe it will work, maybe it wont, but its worth a shot :)
