It is currently Mon Apr 27, 2015 1:48 pm
 Post subject: Game audio recording program?
PostPosted: Fri Jul 30, 2004 6:53 pm
Is there a program that can record all audio running from my sound card? I want to record some audio while I play a game. What's the best program to use? I need it for Win98. Thanks.
PostPosted: Tue Aug 03, 2004 3:37 pm
King of All Voodoo2 Cards
There are a few you can try like Sound Forge or GoldWave.
However I don't think any of them will work because the game you're playing will hog the CPU and the program won't have enough resources to properly record the audio. The reason I'm saying that is that I've had Sound Forge complain that it didn't have enough resources to properly record in certain situations where I was running it alongside with another program.
What I would suggest is run a line from the speaker out to the Line In on another computer if that's an option for you, if not, maybe someone else will have a better idea.
