It is currently Wed May 22, 2013 10:58 pm
 Post subject: Crysis 2 Crashing on first level
PostPosted: Sun Nov 20, 2011 4:18 pm
I recently installed Crysis 2 on my desktop computer. It crashes near the end of the first level, then continues to crash if I try to reload the last save point. Restarting the campaign seems to work, but the game crashes after reaching the same approximate location again. I am running Win 7 64 with an NVidia 8800 GT graphics card. Tech support from the game mfg seems to be non-existant. I have the latest version of the game from what I can tell.
 Post subject: Re: Crysis 2 Crashing on first level
PostPosted: Sun Nov 20, 2011 6:47 pm
what is the rest of your system, cpu and memory, your video card is the minimum necessary, 8800gt with 512 of memory. you could try lowering game settings, you may be trying to play with the settings to high for your system.
PostPosted: Sat Dec 10, 2011 2:04 pm
My system should meet the minimum requirments. I have:
Intel Core 2 Dual E8400 3.00 GHz
6 GB RAM
Win 7 64
EVGA 512-P3-N802-AR GeForce 8800GT Superclocked 512MB 256-bit GDDR3 PCI Express 2.0
PostPosted: Tue Dec 13, 2011 10:11 am
Let the game detect your hardware and set the settings for you. It sounds like something is overheating...like the video card for instance.
Open the side of the case and point a house fan at it at high speed, if the game runs it is a heat issue for sure.
you might also try running in DX9 mode...it will take a big load off the video card.
PostPosted: Tue Dec 13, 2011 11:25 am
the minimum hardware was revised as of game release, one thing that changed was video card.
PostPosted: Tue Dec 13, 2011 9:23 pm
I doubt it's an overheating problem. The program crashes as soon as the saved game is loaded right after starting the game, not after playing for some period of time. Also, if I restart the campaign I can play up to about the same point in the first level, i.e. I kill the bad guys and start exploring.
I found these system requirements at: http://www.crysisdemo.com/crysis-system ... ements.htm. They also listed the old requirements. I will try the DX9 mode and see what happens.
Minimum system requirements
from Crytek and EA
OS - Windows XP or Windows Vista
Processor - 2.8 GHz or faster (XP) or 3.2 GHz or faster* (Vista)
Memory - 1.0 GB RAM (XP) or 1.5 GB RAM (Vista)
Video Card -256 MB**
Hard Drive - 12GB
Sound Card - DirectX 9.0c compatible
Recommended System Requirements
from Crytek and EA
OS - Windows XP / Vista
Processor - Intel Core 2 DUO @ 2.2GHz or AMD Athlon 64 X2 4400+
Memory - 2.0 GB RAM
GPU - NVIDIA GeForce 8800 GTS/640 or similar
* Supported Processors: Intel Pentium 4 2.8 GHz (3.2 GHz for Vista) or faster, Intel Core 2.0 GHz (2.2 GHz for Vista) or faster, AMD Athlon 2800+ (3200+ for Vista) or faster.
** Supported chipsets: NVIDIA GeForce 6800 GT or greater; ATI Radeon 9800 Pro (Radeon X800 Pro for Vista) or greater. Laptop versions of these chipsets may work but are not supported. Integrated chipsets are not supported. Updates to your video and sound card drivers may be required.
PostPosted: Sun Dec 18, 2011 6:05 pm
You could back up your saves and reinstall the game. Something may have been corrupted.
PostPosted: Mon Dec 19, 2011 6:19 am
Those are the minimum specs to run the game and it doesn't, time to upgrade the video card to a 6950 at least.
