It is currently Mon Jun 17, 2013 11:20 pm
 Post subject: Crysis 2 minimum spec requirements
PostPosted: Thu Feb 03, 2011 3:22 pm
These are the minimum specs to just run Crysis 2:
The upcoming Crysis 2 will apparently work on XP, Vista and Windows 7 OS and minimum specs include a Intel Core 2 Duo 2GHz, AMD's Athlon 64 x2 2GHz or better, 2GB of memory, Nvidia 8800GT 512MB, ATI HD 3850 512MB or better and 9GB of HDD space. It is also noted that you'll need an active internet connection, presumably for activation.
I was wondering If I'll be able to max it with my setup. Thoughts,opinions? Thnx.
Setup configuration is :
CPU-Quadcore Phenom X4@3.8 ghz
RAM- 8 gigs of ddr2 memory
GPU- ATI Radeon 5870 1 gigabyte of vram
 Post subject: Re: Crysis 2 minimum spec requirements
PostPosted: Thu Feb 03, 2011 6:47 pm
you should be able to pass with good ratings
