It is currently Sat May 25, 2013 5:24 am
 Post subject: Mic Static Software
PostPosted: Sat Jan 22, 2011 12:36 pm
Does anyone know of any software that cleans up the mic static in real-time? My audio drivers didn't have an option for it.
 Post subject: Re: Mic Static Software
PostPosted: Mon Jan 31, 2011 2:00 pm
like a rock - waitaminute, I AM a rock
I had been looking for such a thing to give to a friend that owns some crazy-expensive $100+ headset that has this incredibly annoying high-pitched whine 100% of the time. I remember reading it was a well known issue with that headset.
I didn't find a fix. But I'm going to keep looking.
What are you trying to do? Record voice/music or are you just looking to cut down on the static on your voice-over-IP software?
PostPosted: Mon Jan 31, 2011 10:19 pm
Celeron
Celeron
Can't recommend any software, but if you're open to it, a cheap USB soundcard would fix it, assuming it is the soundcard.
PostPosted: Thu Feb 03, 2011 10:26 am
Yeah just cutting down static over VOIP. Also, it is for a USB soundcard. (X-Fi Go! Pro)
