It is currently Mon May 20, 2013 5:42 pm
 Post subject: Need Help Bringing angry birds to pc
PostPosted: Sat Dec 25, 2010 2:57 pm
I love that droid game angry birds.
i want to play it on my pc..
Is that possible in the slightest?
 Post subject: Re: Need Help Bringing angry birds to pc
PostPosted: Sun Dec 26, 2010 6:26 pm
If you run linux, you might be able to port it.
PostPosted: Tue Dec 28, 2010 6:15 am
Does the droid allow you to video output to a PC/TV screen? With an VGA cable, and a jail broken iDevice, you can get your games on a larger screen.
Some games allow it already - like Rage HD;
Quote:
2nd Display Support – Play on a TV or Monitor using your iDevice as a controller. Output 480p over the official Apple Component cable & 720p over the official Apple VGA cable.
Does the droid have a 'jail breaking' scene as well? Maybe there is some sort of hack that will allow you to get what you are looking for?
PostPosted: Tue Dec 28, 2010 8:18 am
Yeah, you can root and mod your 'droid devices ... though I haven't heard of a monitor-out function. Doesn't mean it doesn't exist, of course.
Since 'droid uses a linux kernel, I figure porting it to linux should be possible.
PostPosted: Wed Dec 29, 2010 1:34 am
The android SDK has a built in emulator, which you can use to go online and download programs and run them. Its not very efficient, and can be slow to load programs, but it does work.
