It is currently Tue Jun 18, 2013 10:11 pm
 Post subject: I need help with STALKER Complete 2009
PostPosted: Tue Aug 24, 2010 8:24 pm
I installed it and the title and loading screen are different and at the bottom left it says 1.4.4 is installed....but I don't notice any difference, I don't have a sleeping bag. It's just not right. I don't know if it's going and I'm just too stupid to realize it or if the installation went wrong or something (it sayed it was installed correctly). I started a new game. What is or is not wrong?
 Post subject: Re: I need help with STALKER Complete 2009
PostPosted: Thu Aug 26, 2010 10:44 am
I installed these packs on my computer also. If I recall correctly you have to install 1.4.1 (or something like this one) first as 1.4.4 is not a complete build just an upgrade to an older build. Not at home so I can't double check, I will double check for you when I leave work.
PostPosted: Thu Aug 26, 2010 11:22 am
Alright. I will check the website again.
PostPosted: Thu Aug 26, 2010 12:11 pm
I only see the 1.4.4 patch/upgrade/.exe so if you find something please tell.
PostPosted: Thu Aug 26, 2010 2:06 pm
Try looking at fileplanet for older versions. I would look right now but a lot of those sites are blocked where I work at. Like I said in the earlier post I am pretty sure 1.4.4 is not complete and that if you look at the install notes it tells you that. Could be wrong though as I am not at home and can't see what I downloaded or do any searching.
PostPosted: Thu Aug 26, 2010 7:47 pm
Well I just checked at home and I am running 1.4.3 so I got no more advice. sorry
