It is currently Wed Apr 01, 2015 10:05 am
Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 7 posts ]
 Post subject: >>AGE OF KINGS PROBLEM<<
PostPosted: Sat Aug 21, 2010 9:08 pm
I am running age of kings:conquerors (actual gold edition disc) on a toshiba laptop with vista sp2.
I get no music and every 5 mins the colors goes funky and i have to reboot the game.
Any suggestions?
thanks in advance for replies :)
 Post subject: Re: >>AGE OF KINGS PROBLEM<<
PostPosted: Sat Aug 21, 2010 10:36 pm
Million Club
Million Club
Have you tried running the game in compatibility mode? (Right click on shortcut, hit properties, go to compatibility mode, etc.)
PostPosted: Sat Aug 21, 2010 11:35 pm
Yes I've tried all of the compatibility modes and nothing changes. I am using a no-cd crack to play.
PostPosted: Mon Aug 23, 2010 11:43 am
Remove the crack and try playing with the CD. I'd suggest doing a thorough malware scan as well. No-cd cracks often have spyware or malware attached to them, if not by the crack developer, then by a distributor who use them for their own nefarious proposes.
PostPosted: Mon Aug 23, 2010 3:58 pm
Team Creamsicles
Team Creamsicles
XoRn wrote:
Remove the crack and try playing with the CD. I'd suggest doing a through malware scan as well. No-cd cracks often have spyware or malware attached to them, if not by the crack developer, then by a distributor who use them for their own nefarious proposes.
+1. I had a similar problem with a no-cd crack. Get rid of it, and the game worked fine for me.
PostPosted: Thu Sep 09, 2010 6:15 pm
You have to get in game, alt + tab, open task manager, go to the processes tab, and end the process explorer.exe. Trust me, this is the only thing that will fix the funky colors and the weird noises. Upon exiting the game you'll have to restart explorer.exe to see your desktop or taskbar.
PostPosted: Thu Sep 09, 2010 6:35 pm
Weird, I just read about a .dll hack for older games.
