It is currently Fri Feb 27, 2015 4:22 am
 Post subject: Lost Planet 2 benchmark demo for pc
PostPosted: Tue Aug 17, 2010 5:36 am
I was wondering if i was getting a normal score for my system setup. My score is rank c which is about 27 fps average for test a and 28 frames per second on test b (rank c as well)with everything maxed out at 1900 by 1200 resolution with 4 AA. My setup is cpu- Phenom 2 x4 965 @3.8 memory 8 gigs of ddr2 graphics card- AMD 5870 1 gig vr
 Post subject: Re: Lost Planet 2 benchmark demo for pc
PostPosted: Wed Aug 18, 2010 4:32 pm
You had run the test with the graphics settings at maximum? If turning OFF some things and/or lowering resolution improves your score with each test, then yes, that might be normal (at max details) for your PC.
Are you running any antiviral software in the background while running the test? or moving files around in the explorer while playing games?
I had no idea there was a demo out for that game on PC. I will have to check it out when i get home later tonight.
PostPosted: Thu Aug 19, 2010 4:42 am
bingojubes, I have disabled all antivirus software and other unnecessary background tasks. I guess it's normal. It is only a benchmark really not actual gameplay anyway.
