It is currently Fri Jan 30, 2015 7:16 am
 Post subject: HL2 making me sick!
PostPosted: Wed May 19, 2010 1:03 pm
Million Club [PC]
Million Club [PC]
no, no... I love the game, its great! But now that I've finally bought Half-Life 2, it makes me sick... literally. Gives me nausea and dizziness and I have to stop playing. I hear this was a problem for a while... but I don't know how to fix it and I didn't find much on google. I know that in Quake Engine games, view backswaying had the same effect on me, but that could be disabled. No such option in HL2. It's the strangest thing. I can ride the most intense roller coaster ever 10 times and not get sick, but an hour of Half-Life and I'm ready to puke. :(
PostPosted: Wed May 19, 2010 1:35 pm
Is this motion sickness? If it is, enable Vsync or up your refresh rate. Default is 60 for LCDs and 75 for CRTs.
PostPosted: Wed May 19, 2010 10:32 pm
Change your FOV in console.
sv_cheats 1
fov 90
PostPosted: Wed May 19, 2010 11:06 pm
Okay, The above people might have solved this, but I think I know your problem. It might have to do with your depth of field, which is tied to your screen resolution. Try turning up your resolution in game, or if your maxed out, assuming you can afford it, add another monitior, or buy a bigger one
Resistance is Futile,
Borg343
PostPosted: Mon May 24, 2010 11:01 am
Million Club [PC]
Million Club [PC]
Borg343
This is on a 25" 1920x1080 monitor, so I'm not sure that that's the problem. I'll try the FOV thing.
PostPosted: Mon May 24, 2010 12:08 pm
If your going the FOV way, try using this.
PostPosted: Mon May 24, 2010 11:45 pm
Celeron
Celeron
I think they might have updated HL2 so that it includes the FOV slider under the Advanced Video options.
And I had the same issue. Good thing you didn't have to play the whole game through using FOV 70. :(
