It is currently Fri Jan 30, 2015 12:16 pm
 Post subject: Game hacked
PostPosted: Sun May 02, 2010 1:39 pm
Hey guys
I have an account on World of warcraft I have had it several years. SOmeone Hacked my account over the weekend. They somehow started transfering a cpl my characters to another relam. SO Wow told me to run a scan to make sure my puter was clean I just ran search and destroy on my system and it says its clean. So what else should I do now?? so do I need to run something else on my system to make sure?? They told me do not log in till I amke sure my system is clean?? how can someone hack your game account
Thanks for the help
PostPosted: Sun May 02, 2010 5:19 pm
1. Have you ever shared your password with anyone? anyone at all?
2. Do you use the username/password on your WoW account that you do for forums/message boards/ect?
3. Is your password a easily guess password? or is it a "strong" password including numbers/Upper and Lowercase letters/special characters?
PostPosted: Sun May 02, 2010 9:48 pm
I had this happen to me awhile back.
I was phished, learned a lesson about cruising WoW sites when half asleep, but I still scanned with AVG and then Malwarebytes.
Change your login/password, and if possible the email account you have linked to WoW.
I also highly recommend purchasing an authenticator through blizzard, they aren't foolproof, but it does add another layer of protection.
And just some general tips, don't tell anyone your password, don't play WoW on a public computer, and watch out for sites that try to phish your information out of you by looking exactly like blizzards site.
Other than that, not much you can do.
PostPosted: Mon May 03, 2010 12:26 pm
Is the free version of AVG good one?? or do I need to buy it??
PostPosted: Mon May 03, 2010 4:11 pm
AVG used to be my choice of AV, but now all my systems run Microsoft Security Essentials. In most ways its far superior.
PostPosted: Mon May 03, 2010 6:02 pm
I use Free AVG, the Microsoft one Airheadq mentioned is good too.
PostPosted: Sat Jul 24, 2010 8:42 am
I also use MCSE
Since I had my account hacked pre mcse, I did a couple things to help.
One was installing MCSE, the other was installing an extension in chrome that blocked flash.
I was told by a bliz rep that some sites can infect your pc via flash and I had that problem specifically with piratebay.
So new virus protection, a new extension that blocked flash and I leave no sites up when I log into WoW.
The last thing you should do, buy an authenticator. Its 6 bucks.
PostPosted: Mon Jul 26, 2010 5:24 am
Some UI add-ons are used to hack WoW accounts.
What kind of UIs do you use?
PostPosted: Thu Jul 29, 2010 4:00 am
Did you get an email for WoW Cataclysm beta and sign up for it using your username and password? There are a lot of fake sites out there that are copies of the legit site so, they can steal your username and pass that you enter. Becareful when you get emails for any mmo. My WoW account has been disabled for sometime now and I keep getting emails that say my account will be banned if I do not go to this site and log on to confirm it.
So take care with those sites.
