It is currently Fri May 24, 2013 3:29 pm
 Post subject: Tell me how this works >.>
PostPosted: Sun Mar 21, 2010 6:05 pm
Team Member Top 1000
http://store.steampowered.com/app/7610/
I was looking into buying Sid Meier's Railroads, and then came across the deal to buy Railroad Tycoon 3 and 2 Deluxe for $5 more. However, it says that RT3 is not compatible with Vista or 7, but RT2:D is? How does that make any sense?
AJ
PostPosted: Sun Mar 21, 2010 6:09 pm
You can get it running, just check the forums for the workaround.
PostPosted: Sun Mar 21, 2010 8:12 pm
If you mean the Steam forums I found the post - it's amazing how one thing can throw a game for a loop, but not affect an older game - thanks for making me not be lazy and search.
AJ
PostPosted: Sun Mar 21, 2010 8:34 pm
AJ
Haha, anytime.
