It is currently Sun Mar 29, 2015 10:03 pm
 Post subject: Save Game Files
PostPosted: Wed Mar 10, 2010 2:24 pm
I have several save files from my old pc running xp 32 bit, that i have not imported. Being the dumbass i am (without dropbox) I tried emailing myself my batman arkham asylum save file, and it got corrupted. In additon to this save file, I also have a save file for Civ 4 and Burnout Paradise that i would, like to bring to my new pc running windows 7 64 bit. How do I move the save files correctly, and put them into the right folders?
PostPosted: Wed Mar 10, 2010 3:32 pm
i would install those games, make a new profile in each of them, and see where the saves go after exiting.
i think most of the games put them in the My Documents folder in Windows 7. do check both the My Documents folder, as well as maybe the My Games folder. Sometimes they can also be in the (usually) hidden AppData folder in your User folder - either in the Local or Local App folders, under the game company.
i don't imagine that most saved games can get very large in file size, so you can also use USB drives to carry them over between computers. when i usually finish a game, i will incorporate the Root save folder directory into my yearly backups, so i don't have to replay much of the game down the road.
