It is currently Tue Jan 27, 2015 12:30 am
 Post subject: New Computer Questions
PostPosted: Tue Jul 20, 2004 3:30 am
I am looking into buying a new computer and I had some questions. I am looking an an AMD FX 53 with 2x1gb of ram with and XT800 XT with about 250 gb hard drive. I have checked out a couple of different places online that build comps like ABS, Falcon and Alienware. What are some of the other good companies that I should check out? Is there anything that I am missing to make a kick ass gaming machine?
Thanks for the help.
 Post subject: Re: New Computer Questions
PostPosted: Tue Jul 20, 2004 4:31 am
www.voodoo.ca
Also, unless you have money to burn and want bragging rights for the next few months (until the 90nm Athlon 64's with PCI-E and the R500/NV48s debut), I'd recommend something slightly less powerful.
Something like an Athlon 64 3500+, and a GeForce 6800 GT with 1GB of RAM will be nearly as fast in actual game play, but cost about $650 less.
As far as the gaming experience goes, the things I would recommend are a good mouse and mouse pad (all preference, Logitech makes good stuff), a good monitor (remember, monitors don't go out of date, so while spending $800 on a CPU that will be middle of the pack in 12 months, spending $800 on a Dell 2001FP that will still be kicking 5 years from now isn't so silly). Games play better through headphones, and the Audigy 2 is stil the best gaming sound card.
Other than that, your videocard is the most important part, and I prefer two physical hard drives. One of your OS/Games/Applications (like a 74GB Raptor) and the other, larger drive for your data/backup.
PostPosted: Wed Jul 21, 2004 2:00 am
Thanks for the input. I was going to go all out so I didnt have to upgrade for a longer amount of time. You were saying that headphones sound better then speakers. Is that still true if I buy 5.1 or 7.1 speakers from like Creative or Klipsch?
PostPosted: Wed Jul 21, 2004 6:14 am
You only have two ears (or two points of input), so in FPS's with good positional sound and a good soundacard, headphones are *way* more accurate. Back in CS days I got a few kills shooting through walls based on sound alone.
*Better* is subjective, but I also live with people who wouldn't apprecaite the booms and thumps of games blaring through a set of 400W Klipsches.
