It is currently Mon Jan 26, 2015 5:44 am
 Post subject: linux on Htpc
PostPosted: Wed Nov 04, 2009 11:58 pm
How well does Linux work as an OS for HTPC (ubuntu 9.10 most likely) just wanted to know what experience and issues i can expect.
PostPosted: Thu Nov 05, 2009 6:40 am
It's going to depend on your level of experience and knowledge of Linux in general. But in general, it works well and there are distributions geared specifically towards HTPC (Mythbuntu for example).
PostPosted: Thu Nov 05, 2009 5:20 pm
Thanks for the heads up i did not know that Mythbuntu existed. Are there any hardware pieces that any one knows of that has hardware issues.
PostPosted: Thu Nov 05, 2009 8:20 pm
TravBv2.0
TravBv2.0
Linux is pretty damn easy. It only gets harder when your needs become more complex. Then again, Linux being "hard" is subjective.
Linux on the HTPC is pretty good for basic uses but it depends on what you're doing. If you were looking to build something just to keep all of your movies and music on it, you'd probably find it easier to just use Windows Media Center in Vista or 7.
Now if you were talking about a rig to store and stream all of your media to various PC's around the house, a MythTV backend can be awesome.
As for hardware, it's been a while since I took a look at what MythTV was compatible with. I've heard from those before me that MythTV is a bitch to setup though. It could've changed in the last year or so, but I doubt it. Eitherway, there are plenty of guides and how-tos online to help you out along the way.
