It is currently Wed Apr 01, 2015 10:37 am
 Post subject: Debian won't install!!!
PostPosted: Fri Jan 14, 2005 8:14 am
i'll install cd1 just fine, than it reboots so it can finish the install from the hard drive, but when it does this it gives me this error:
pivot_root: No such file or directory
/sbin/init: 426: cannot open dev/console: No such file
<0>Kernel panic: Attempted to kill init!
I've tried reinstalling several times and have even downloaded the image again...any help?
Comp: Compaq presario r3000
PostPosted: Fri Jan 14, 2005 11:55 am
iron colbinator
iron colbinator
What are you installing from? Which version?
PostPosted: Fri Jan 14, 2005 3:45 pm
hmm...i formatted the hard drive with ntfs then re-installed and it worked
thanks though!
