It is currently Tue Mar 03, 2015 2:36 pm
 Post subject: removeable disk help!
PostPosted: Tue Aug 25, 2009 12:49 pm
I'm making my first Ubuntu 9.04 server, its got 9 HDDs in it right now. All of the drives are in NTFS, and every time i reboot, i have to manually go to places > removable media and click on them to mount them to //media. i know little about how Linux works (I'm a windows boy) so i need a way to mount all of these drives permanently.
Thanks! And sorry if I'm vague, I'm still new to the whole Linux thing..
PostPosted: Tue Aug 25, 2009 2:41 pm
go to Adminitsration> Disks, write down the partition names (they should look like /dev/hdb* or /dev/sdb*), write them down. make a folder for each drive(/media is good spot). now open up the file etc\fstab and add a line like this at the bottom for each drive.
/dev/foo media/mountpoint ntfs users,rw,owner,umask=000 0 0
Where dev/foo is the name of the partition, mount/point is the mount point, and ntfs is the filesystem, so you dont need to change that.
PostPosted: Tue Aug 25, 2009 2:42 pm
and these are external HDs that you have hooked up at once?
I suppose you could add something to fstab as freak suggested, but I'm not sure that's entirely the right approach here.
I guess I'm just confused how removable media is coming into play here or just puzzled as to what you're doing and what you're wanting to happen, outside of wanting them to automatically mount.
PostPosted: Tue Aug 25, 2009 3:40 pm
Monkey Federation (Top 10)*
You could go the route Freak suggested or you could look at udev rules. I quickly looked this over and it should at least get you started:
http://ubuntu-tutorials.com/2006/12/06/how-to-always-mount-removable-drives-in-the-same-place-ubuntu-6061-610
PostPosted: Tue Aug 25, 2009 4:17 pm
Thats why im confused, these are INTERNAL IDE HDDs. but linux is seeing them as removable disks.
I'm going to try that now, thanks for the input!
EDIT: for do i open etc\fstab?
And i dont have "Disks" under Administration, do i have to install Gparted? ill do it anyway...
PostPosted: Tue Aug 25, 2009 4:45 pm
go into a terminal and type sudo gedit /etc/fstab
You should be able to list all your partitions via
sudo fdisk -l
in a terminal also.
Alternatively running gnomesu through run application should open a terminal with the proper permissions also (admittedly, I've never tried that in Ubuntu though).
Doing on a google with mount ntfs fstab should give you plenty of results on what needs to go in there.
I guess if they're not mounted, I could see why they'd show up in removable disks.
PostPosted: Tue Aug 25, 2009 6:22 pm
Million Club - 5 Plus*
You probably want to use ntfs-3g as the filesystem instead of ntfs. ntfs-3g is the ntfs driver that allows for read-write interactions.
