Casablana
0.4
http://kde-apps.org/content/show.php?content=11464
a simple graphica FTP program for KDE. I plan to use it for my website. It compiled with out any issue I recall and installed happy too. I did cause it die in a second by placing the wrong text in the host:port text box when setting up B side. I got it back did it right and it went happy.
KWirelessMonitor
0.2.8
http://kde-apps.org /content/show.php?content=11576
It built and installed fine. I don have a problem with it borking. If I run it with --fork it runs fine sorta
I might need to play with it a bit.
KNetworkLED
0.5.1
http://www.kde-apps.org/content/show.php?content=13972
simple and works. not very exciting but does its thing
I need to do more shopping at
http://kde-apps.org
joyd
0.2.2
http://www.h.shuttle.de/mitch/joyd.en.html
http://sourceforge.net/projects/joyd/
A simple app bit dated but it works.
Well that what Im playing with now
Feel free to post less know apps you use. Please try to keep with the format ie:
app
version
links
description
