It is currently Mon Mar 30, 2015 3:17 pm
 Post subject: Ubuntu on PS3
PostPosted: Mon May 04, 2009 4:06 pm
I read the article on installing ubuntu on ps3, and installed without any problems except when I try to boot there is no desktop? It is strictly just the terminal. Did I miss a step?
PostPosted: Mon May 04, 2009 6:21 pm
Which article did you follow exactly?
This one, for example, does include the steps to install a GUI.
PostPosted: Mon May 04, 2009 6:22 pm
Team Member Top 1000
I think he is referring to the one in the June 2009 issue... let me look to see if you missed a step.
AJ
PostPosted: Mon May 04, 2009 7:14 pm
AJ
Yes, that is correct. I get into the bootloader and push enter instead of typing in the install line, and it takes me into the terminal. I asked a friend of mine, who is familiar with linux, and he said to use startx or xstart, I forget which one, but it doesn't seem to work either. Perhaps there is a step missing from the article.
PostPosted: Mon May 04, 2009 7:35 pm
TravBv2.0
TravBv2.0
Have you tried making sure it's installed?
sudo apt-get install xorg gnome
If It's installed, it will check the version in the repos against the installed version and update if necessary. If it's not installed, it should install without issue. You may need to do some editing of your xorg.conf, but it should work fine.
PostPosted: Tue May 05, 2009 10:29 am
Tried this, and it says "Could not find package xorg". Any update on corrections / missing parts from the June Article?
PostPosted: Tue May 05, 2009 6:40 pm
TravBv2.0
TravBv2.0
Could you post the output of
cat /etc/apt/sources.list
PostPosted: Wed May 06, 2009 9:47 am
There is a lot of stuff. The only way is via image. I hope you can see clearly...
PostPosted: Wed May 06, 2009 10:02 am
Run "sudo apt-get update" and then try install xorg again.
PostPosted: Wed May 06, 2009 11:23 am
Alright well I have been trying a lot of different things. It turns out that my wireless wasn't getting through, even though I changed it to WEP. So I managed to setup an Ethernet cable to my PS3, and am attempting to re-install because last time I used one of the 1080i video modes, and the portable TV I have doesn't support that. So I will update on the status once I see how this goes.
Few questions... 1) If I install without using the special install line for HD, will I be able to switch to it after its done? 2) If I use hardwire during install, will I be able to switch to Wireless with WEP once I am completed the installation?
**UPDATE: So far so good. Did the update command, and now downloading xorg. Both made connection to internet, and were a success.
**UPDATE2: Everything worked out fine. The GUI is working. Thanks for all the help. Still looking to get those 2 questions answered, as well as wondering about should I update Ubuntu? There are 58 updates waiting to be installed, but I was thinking the newer versions might not work well with the PS3 or something. Let me know. Thanks again.
PostPosted: Sun May 10, 2009 10:34 am
From what I understand...Ubuntu will run fine on the Ps3...but you will not be getting all the benefits...
Yellow Dog Linux has a version specifically written for the Ps3...and takes full advantage of the cores that Sony will allow access to.
Just a thought.
Glenn
PostPosted: Fri May 15, 2009 7:22 am
Both versions run under the exact same hypervisor, there is no difference between using ubuntu and yellowdog now
