It is currently Mon Jan 26, 2015 3:13 pm
 Post subject: Soundblaster x-fi
PostPosted: Sat Apr 18, 2009 8:25 pm
Ok I have:
soundblaster x-fi Fatality
Ubuntu 8.04
nvidia 680i mobo
How do i make the soundcard work with Ubuntu? I'm really new to the whole linux experience, and Soundblaster has a new driver for it but i have no idea how to install it?
Thanks for any help.
8)
PostPosted: Tue Apr 21, 2009 12:29 pm
You might want to PM "that Linux guy" as he has a creative card running under Linux i believe.
PostPosted: Tue Apr 21, 2009 1:49 pm
What aren't you understanding? The readme seems pretty straight forward
1) Goto source directory
2) Execute make command as root
make
make install
Since you're using ubuntu the commands you'll want to use are
sudo make
sudo make install
PostPosted: Tue Apr 21, 2009 4:27 pm
Ok look I am an utter noob at this. LOL so when you tell me to Go to source directory, you mine as well be speaking spanish. lol
PostPosted: Tue Apr 21, 2009 5:16 pm
Oh.
The source directory is what you just extracted from the tarball. Looking at the file, you probably have a folder somewhere called XFiDrv_Linux_Public_US_1.00
The folder does contain source code..thus the term.
Changing directories is exactly how you'd expect it through a terminal window. Not much difference between here and Windows.
