It is currently Mon Mar 02, 2015 7:11 am
 Post subject: EMERGENCY!!! My Vista just dissapeared...
PostPosted: Sat Mar 28, 2009 11:52 am
Alright guys, I need some critical help. I just installed Ubuntu 8.04 on my home desktop, attempting to dual boot My vista 64bit business. I was following this guide:
http://apcmag.com/how_to_dualboot_vista ... _first.htm
It was fairly straight forward and basically said partition and install, the grub boot loader would take care of the rest. I already had a partition set aside when I first set up my computer, so i just threw in my disc and got started.
OK, my partition I had originally set aside was 250gb, and I decided it would be overkill, so I used a guided partition that took 50Gb from my vista partition and would make that my Linux partition, I figured I would just reallocate the other 250gb partition later. The install went smoothly and I just rebooted a few minutes ago. Here comes the problem.
The grub boot loader doesn't give me the vista boot option, only 3 linux options, the regular boot, recovery boot, and something else. I really need some help. I know very little about this kind of thing and have only used basic command line things. I don't really know what information or files to post that show information.
i know the partitions are still there and haven't changed, they are listed under places in linux and i can access them. Please someone help me get my vista back...
PostPosted: Sat Mar 28, 2009 4:19 pm
Can you go into a terminal and type sudo fdisk -l and post the results?
Hopefully, you didn't choose "use entire disk", which is what I believe the default is, when installing.
The above command should show you all the partitions on your system.
PostPosted: Mon Mar 30, 2009 4:05 am
Also post this for us:
sudo cat /boot/grub/menu.lst
We really don't need the entire contents of the file, but it is better to be safe than not.
PostPosted: Sat May 16, 2009 3:53 am
Quote:
My Vista disappeared
Good riddance! :D
PostPosted: Sun May 17, 2009 11:13 am
yurimxpxman wrote:
Good riddance! :D
Don't be bumping old threads...
