It is currently Sat Jan 31, 2015 5:06 pm
 Post subject: Ubuntu as a Firewall
PostPosted: Thu Feb 19, 2009 5:19 am
Just looking to see if there is anything obvious that I might have missed...
I followed this guide...
http://ubuntuforums.org/showthread.php? ... c&t=926001
and it doesn't appear that I am getting any IP address from the box when I try to use it in place of my Linksys router.
Has anybody else done this recently? Have any other suggestions? I want to be able to use this box as an FTP / file server / web server (maybe) etc as well. I picked Ubuntu because due to my last job it was the distro I have used the most / most recently and I was reasonably familiar enough with it to make it work how I wanted to.
 Post subject: Re: Ubuntu as a Firewall
PostPosted: Thu Feb 19, 2009 9:44 am
I haven't done a linux router in a long time.
I'm confused about this though..
Is it not handing out addresses to other machines or can you not see the box on your LAN?
The first would steer me towards DHCP. The second, I'd probably be using static IPs in the same subnet as everything else.
PostPosted: Thu Feb 19, 2009 11:12 am
Client machines don't get IPs from the Router/Firewall box.
I set up DHCP3, and the subnet, and all that jazz. Just like the guide says. I get a virtual/private 169 ip address.
The nic (eth1) that is supposed to dish out IP addresses has a static IP of 192.168.0.1 (just as in the guide). eth0 (internet) is DHCP.
PostPosted: Thu Feb 19, 2009 11:30 am
Hopefully someone else will chime in.
Would staticly assigning an IP on the one that's supposed to get an address confirm anything?
PostPosted: Sat Feb 21, 2009 12:21 am
I just got done setting this up, but I am using OpenSuSE 11.0. I am using a separate dhcp server. Did you set the dhcp service to be bound to eth1? I'll do some looking to see how to set that up in Ubuntu.
PostPosted: Sat Feb 21, 2009 7:41 am
TravBv2.0
TravBv2.0
Crash, you need to comb through your DHCP3 conf file to see what's up. DHCP isn't working on that interface and APIPA is taking over, hence the 169.254.x.x IP addy.
I remember getting DHCP3 setup, but I had release time issues. I didn't know whether the numbers meant days, weeks, minutes, seconds.... never did get an answer to that one.
PostPosted: Sat Feb 21, 2009 9:22 pm
Million Club - 5 Plus*
Use dnsmasq for DNS and DHCP on the subnet. It's MUCH simpler.
I followed this on my Arch machine (with the additional NAT steps), and it's been running for me for over a year and a half:
http://wiki.archlinux.org/index.php/Sim ... wall_HOWTO
dnsmasq part of Arch wiki (on different page)
PostPosted: Sun Feb 22, 2009 7:15 am
I will try those suggestions out when I get home (out visiting the fiance right now). I was just hoping I may have missed a step with the DHCP. It seemed pretty simple to set up.
