It is currently Sun Jan 25, 2015 9:30 pm
 Post subject: OKay, I am at a loss here...
PostPosted: Wed Feb 11, 2009 5:25 am
Trying to set up an Ubuntu (8.10 server disc, freshly downloaded) server... Pretty simple hardware wise...
1.4 Ghz T-bird
ASUS A7V (http://www.dansdata.com/a7v.htm)
1 GB SDRAM
80 GB HHD (Seagate, don't know the model) IDE
Cd/DVD burner, Lite-On I believe (or LG?) IDE
Riva TNT2 AGP (hey! I had it laying around)
Adaptec Sata Connect card (currently empty, do plan to install drives later)
Boots to the CD just fine, loads the set up, I can partition and install just fine. Machine reboots and one of two things happens. I get a black screen with a blinking _ cursor OR I get a disk failure / OS message (don't remember exactly...)
Thoughts?
PostPosted: Wed Feb 11, 2009 5:27 am
How old is that hard drive?
PostPosted: Wed Feb 11, 2009 5:30 am
"Old". Not sure exactly on the age. maybe 6 or so years? I am pretty sure it worked before... bios detects it, it obviously spins up, ubuntu properly reads it's size.
PostPosted: Wed Feb 11, 2009 5:48 am
Hrm. There goes the easy answer. :(
I think we need the error message that you see to diagnose this further.
PostPosted: Wed Feb 11, 2009 6:12 am
It could still be the drive though... I haven't ruled it out. i didn't think to check it further because it was working for the install fine. It just doesn't boot up after install...
I am 98% sure this is the error message if I don't get the blinking cursor:
"DISK BOOT FAILURE, INSERT SYSTEM DISK AND PRESS ENTER"
PostPosted: Wed Feb 11, 2009 6:25 am
Are you doing the direct install or are you loading up the Live OS first then installing?
I seem to always have issues if I don't load up the Live OS first.
It sounds like your MBR is toasted.
PostPosted: Wed Feb 11, 2009 6:26 am
Yep, that sounds like an MBR issue to me as well.
PostPosted: Wed Feb 11, 2009 6:50 am
The server install disc does not have a LiveCD installer. I will drop a LiveCD in and pre-partition / do my disk stuff (new partition tables probably in order) then do the server install?
PostPosted: Wed Feb 11, 2009 7:30 am
You could start over.
First fix the MBR.
You can do this by booting to XP cd and choosing repair option.
FIXMBR
FIXBOOT commands
Then go your route as you stated.
Should be kinda fool proof that way.
PostPosted: Wed Feb 11, 2009 7:50 am
TravBv2.0
TravBv2.0
Why not just run supergrubdisc? I'd had MBR problems in the past, and if you're using Linux on your rig at all SGD is a great thing to have around.
http://www.supergrubdisk.org/
PostPosted: Wed Feb 11, 2009 7:54 am
Cool.
I'll have to check that one out.
PostPosted: Wed Feb 11, 2009 8:17 am
I will report back what works. Thanks!
PostPosted: Wed Feb 11, 2009 4:24 pm
Okay... this is retarded...
Blindly fumbling in the BIOS I turned off the second channel on the primary IDE controller (killing the channel the CD drive is on)
I get a grub menu.... wtf?
I go back, reset everything, turn it back on... blinking cursor
::scratches head::
enable onboard promise ide, switch dvd drive to secondary controller...
::waits extra time for the secondary controller bios to boot::
grub menu...
this is retarded. I don't want to put the CD drive on the other controller if I don't have to....
