It is currently Fri Mar 27, 2015 6:28 pm
Post new topic Reply to topic  [ 26 posts ]  Go to page Previous  1, 2
PostPosted: Thu Feb 12, 2009 3:16 pm
Monkey Federation (Top 10)*
maniacm0nk3y wrote:
I finally burned my 1st AudioCD. Thank you Lodis4.
I could easily use Mint over Windows if it wasn't for PC Games, and broken Flash in Mint.
Flash is broken? I am running Fedora 9 64bit and it works for me. Youtube and flash games are really all I have tried though. The distro really does not have anything to do with limiting flash. Unless you want a pre-built package and none are available.
Post details. Someone will chime in with help.
PostPosted: Thu Feb 12, 2009 8:10 pm
it's probably trying to use nnpluginwrapper and crapping out.
Monkey: did you install x64 or x86? Going to a command prompt and typing uname -a should be able to tell you this if you're not sure.
PostPosted: Fri Feb 13, 2009 3:39 pm
Which mint are you using? You might have to reinstall flash.. because the older version had some problems. Ask a question on the mint forums.. I know there's a quick fix (I use mint too.. but I don't know exactly how to do it.).
PostPosted: Sat Feb 14, 2009 10:26 pm
Well I will try to install again. I have Distro 6, the most recent one.
It just greys out or just stops playing and stuff like that.
How do I rip audio into Mint. No program does that, there are only burning programs.
PostPosted: Sun Feb 15, 2009 6:12 am
Rip from cd to mp3? GRip is probably the easiest way. There are many tools you could use but GRip will get you going the quickest.
PostPosted: Sun Feb 15, 2009 7:42 am
How to rip....I got GRip. The menus are "different" I selected the mp3encoder but there is no choice about bitrate and stuff.
