It is currently Tue Mar 31, 2015 12:57 am
Post new topic Reply to topic  [ 26 posts ]  Go to page 1, 2  Next
 Post subject: Linux Mint/Ubuntu questions
PostPosted: Tue Feb 10, 2009 8:42 pm
I just installed Linux Mint and love it. There are questions though. I have a MP3 data cd and when I transfer the files onto the desktop they are locked. How do I allow the computer to "own" these files, so to say (what I read in forums and stuff).
Also, what are some good replacements for Windows programs....just from every corner and type of program there is.
I tried to add a file from a particular folder into a burn project...and it just freezes. Completely. I thought these OSs are supposed to be more stable? Everyone says that it deals with the codecs and stuff....
So I guess I would like to know what type of codecs I should get for my OS. Also, I installed VLC...pretty nice, actually plays movies....only the ones I copied as a file.
DVDs won't play...yet.
I don't want to drag this on, so I'll wait for answers.
PostPosted: Wed Feb 11, 2009 5:50 am
Right-click on a file to change the file settings, including read/write permissions.
For app replacements, please read the stickies and existing threads.
What burning software are you using?
VLC should play DVDs just fine. So long as you have a 'net connection, it will also go out and grab the necessary codecs when you open a file.
PostPosted: Wed Feb 11, 2009 8:39 am
I used Brasero and that KcD....those two. Both froze up on particular folders.
For file permissions I saw something but it said nothing about being able to read AND write.....also, the locks were still showing on the folders when I changed the settings.
PostPosted: Wed Feb 11, 2009 9:08 am
Maybe I'm not using the right geritol...I've never had this occur in 'nix. Is this distro specific maybe or is there something that can be configured.
PostPosted: Wed Feb 11, 2009 9:18 am
Really? VLC 0.9 played DVDs for me 'out of the box'.
I wonder if I had already installed a dvd-decrypt codec and VLC simply picked it up? I'm not sure .. this box has been going for about 3 years now and I don't keep a changelog. I have enough of that shit at work. ;)
PostPosted: Wed Feb 11, 2009 9:21 am
Monkey Federation (Top 10)*
I thought VLC came with the libdvdcss library when you installed it. Install VLC and play DVD's; doesn't get much easier than that.
PostPosted: Wed Feb 11, 2009 10:02 am
yea..I had to install things like win32, dvdcss separately. I'll add that at one time, I had to get modified versions of players like totem or mplayer for that to work there (VLC wasn't around then)
Mostly everything I run is RPM and I would doubt that there's a forced dependency for this to be loaded because of the legalities that hovered over this for a while, so that may explain why I never saw it and while I still need to load that.
PostPosted: Wed Feb 11, 2009 2:39 pm
Well it worked for an .mp4.
Will update when I try out other movies.....
How do you rip CDs into Amarok. There is nothing about CDs, except to play them, from what I see.
PostPosted: Wed Feb 11, 2009 3:11 pm
Amarok is noting more then a player.
I don't use Amarok enough, but I beleive it does interface with K3B for this purpose. This should steer you somewhere on that..
http://www.howtogeek.com/howto/ubuntu/w ... in-ubuntu/
PostPosted: Wed Feb 11, 2009 9:51 pm
Thanks. I'll have to read that tomorrow morning. Videos work, finally. Must be a combination of Mint and VLC with their pro-codec way.
Texas Chainsaw Massacre worked well. Good movie, the classic.
Edit: I thought this was just the background but I can actually see the "scan lines"...I thought this was only supposed to happen on CRTs? Is it the driver, maybe? I have integrated Intel on a G31, Gigabyte model.
PostPosted: Thu Feb 12, 2009 8:09 am
I can't burn using Brasero or K3d. Says I don't have the codecs...yet I can play all my songs fine and I burned before, on Ubuntu a long time back but now they don't want to do a thing.
PostPosted: Thu Feb 12, 2009 8:10 am
What KIND of files are you trying to burn and kind KIND of files are you turning them into?
If you were burning a data CD or DVD, the app does not need a codec .. it is just burning 1s and 0s. It only needs a codec if it is trying to convert from one file format to another.
PostPosted: Thu Feb 12, 2009 8:12 am
VLC sucks...
o wait. You don't have much of a choice with *nix. Never mind. :)
PostPosted: Thu Feb 12, 2009 8:26 am
-Crash-
Why does VLC suck? I liked it, but lately it hasn't worked..but it is fine on Mint.
-Jipstyle-
I am trying to burn MP3s onto a disc as an "audio disc" for playing music in my car. It says they need to be in .wave . Where would I get the codec so I can just rip and not have to convert myself, then burn it?
This is the first time this has happened in Ubuntu/Mint, where it actually had a problem burning as an audio cd. Last year, when I used Ubuntu (temporarily) it never said anything about converting it.
PostPosted: Thu Feb 12, 2009 8:31 am
I am just not a fan of it. I am sure it works just fine under linux. In Windows? Meh I don't bother. It was buggy and gave me BSODs and choppy playback.
PostPosted: Thu Feb 12, 2009 9:59 am
CrashTECH wrote:
VLC sucks...
Hehehe ... while VLC is my player of choice for XP, I don't use it in linux. Go figure. :P
Maniacmonkey: http://www.wikihow.com/Burn-a-CD-in-Ubuntu-Linux
If you follow those instructions and it still doesn't work, we'll dig deeper.
PostPosted: Thu Feb 12, 2009 10:59 am
With Ubuntu you can auto load almost all of the codecs you need by:
Open Add/Remove...
Change the top drop down to say:
All Available applications
In the left box click on:
Other
In the right box scroll down to:
Ubuntu restricted extras
Check the box and hit:
Apply Changes
This will install:
flashplugin-nonfree [i386]
Adobe Flash Player plugin installer
rec: gstreamer0.10-ffmpeg
FFmpeg plugin for GStreamer
rec: gstreamer0.10-plugins-bad
GStreamer plugins from the "bad" set
rec: gstreamer0.10-plugins-bad-multiverse
GStreamer plugins from the "bad" set (Multiverse Variant)
rec: gstreamer0.10-plugins-ugly
GStreamer plugins from the "ugly" set
rec: gstreamer0.10-plugins-ugly-multiverse
GStreamer plugins from the "ugly" set (Multiverse Variant)
rec: libdvdread3
library for reading DVDs
rec: liblame0
LAME Ain't an MP3 Encoder
rec: msttcorefonts
Installer for Microsoft TrueType core fonts
rec: sun-java6-jre [amd64]
Sun Java(TM) Runtime Environment (JRE) 6 (architecture independent files)
rec: sun-java6-plugin [i386]
The Java(TM) Plug-in, Java SE 6
rec: unrar
Unarchiver for .rar files (non-free version)
PostPosted: Thu Feb 12, 2009 11:10 am
GnomeBaker will add one song, then the whole program will close.
I checked, all of those libraries and flash, and everything else is already installed.
Stuck....still.
PostPosted: Thu Feb 12, 2009 12:10 pm
maniacm0nk3y wrote:
-Jipstyle-
I only use K3B, it works so I have no reason to switch. That being said. To make a cd for playing in the car the songs need to be in .cda format not .wav (unless they are the same and I don't know it)
You mentioned K3B does not like mp3 files. Do you have the libk3b3-extracodecs package installed? That will enable mp3 support. It does the conversion on the fly; you just drag the .mp3 files to the project and burn when full.
PostPosted: Thu Feb 12, 2009 12:39 pm
I finally burned my 1st AudioCD. Thank you Lodis4.
I could easily use Mint over Windows if it wasn't for PC Games, and broken Flash in Mint.
