It is currently Mon Mar 30, 2015 4:44 pm
 Post subject: Libgcrypt installation problems
PostPosted: Wed Jan 28, 2009 11:10 am
Team Member Top 250
Team Member Top 250
I have ubuntu 8.04 and I can't get Libgcrypt-1.4.4 installed because it requires libgpg-error to be installed first. After I run the
./configure
it gives me this error before finishing:
./configure: line 14537: syntax error: unexpected end of file
Therefore I can't run the make and make install. Any ideas?
PostPosted: Wed Jan 28, 2009 11:36 am
Any particular reason you aren't using the Synaptics Package Manager? It is one of the main reasons for using Ubuntu.
I've checked and verified that that package was included with 8.04, so you should be good to go.
