It is currently Tue Mar 31, 2015 1:59 am
 Post subject: Fedora Core 3 Boot Problems UPDATED!
PostPosted: Thu Dec 30, 2004 11:53 pm
I install Fedora Core 3 fine, get it all good till i get to the boot where i get stuck on
Configuring Kernal Parameters:_
then it stops
dont know how, dont know why
i am using an old school HP with an Intel pent processor at about 800 mhz
completley formatted the hard drive a few times, so its just FC3 on it.
I'm using the workstation setup with no ethernet card activated on boot and ive tried with active on boot
im using a ps/2 mouse and keyboard, nothing else is plugged in cept my monitor
and the checksums on my iso images are all matches of the ones that fedora did
HELP ME! PLEASE!
EDIT!! NVM i fixed it (well, my bud online did) and all u gotta do is enter the fedora menu (the one that shows ur different OS's) and then u hit a i believe and remove
rhgb
that will do it
UPDATE!
I CANNOT CONFIG MY X!
ive tried x86config but it says no such command!!!!!
PostPosted: Fri Dec 31, 2004 10:07 am
iron colbinator
iron colbinator
You mean xf86config?
My guess is that Fedora uses X.org, in which case you want to try xorgconfig.
PostPosted: Fri Dec 31, 2004 10:09 am
7yrs+11,000 Posts
7yrs+11,000 Posts
That happened to me when I didnt have enough hd space. Do you have at least 4 gigs?
PostPosted: Fri Dec 31, 2004 12:12 pm
ya i got a 30 gig drive
ya, apparently Fedora switched from x to x org so they really missed the point on that one....
so i am just downloading either suse or FC2
most likley fc2
can anyone tell me the checksums of FC2 disk 1-4 iso because they do not have them posted like the FC3's are
PostPosted: Mon Jan 03, 2005 7:07 pm
I have my doubts that FC2 is going to help any..
IIRC, it used to be redhat-config-xfree86, and then with the release of 3 it was changed to system-config-display
And your checksums can be found here..
http://download.fedora.redhat.com/pub/f ... /i386/iso/
PostPosted: Mon Jan 03, 2005 7:22 pm
tyvm furball
and ill try that after my alg2 and bio homework
cuz it might work
ps: Format in the future of that computer LOL
ps: i dont see any checksums... u gimmie rite link?
PostPosted: Mon Jan 03, 2005 7:24 pm
iron colbinator
iron colbinator
Zambini wrote:
tyvm furball
cuz it might work
The file is called "MD5SUM"
http://download.fedora.redhat.com/pub/f ... iso/MD5SUM
PostPosted: Mon Jan 03, 2005 7:54 pm
nah. nah, i need the numbers
not the program, i gots md5sum already
PostPosted: Mon Jan 03, 2005 7:57 pm
open up the file with notepad and prepare to be amazed...
PostPosted: Mon Jan 03, 2005 7:59 pm
mhh huh
they should word it better cuz i assumed it was the md5sum exe thing
ps: ty
