It is currently Fri Jan 30, 2015 7:54 am
Post new topic Reply to topic  [ 19 posts ]
 Post subject: Permission problem with Ubuntu 8.04
PostPosted: Fri Jan 23, 2009 7:47 am
I just tried doing the Coolbits hack to my xorg.conf, but when I tried to save the change a banner came up across the top of my gedit window saying:
Quote:
You do not have the permissions necessary to save the file. Please check that you typed the location correctly and try again.
My account is the only one on this machine, so how could I not have the permissions?
PostPosted: Fri Jan 23, 2009 7:51 am
If your account is the only one on that machine, then you need to set up another account. You need two accounts (minimum) for a well-built linux box. One is your personal account that you use day-to-day and the other is the root account that you use when you're administering your box.
Take a look at the permissions for the file you are trying to access and the folder in which it resides. The easiest way to do that is to type 'ls -la in the folder itself.
We want to see the complete line for the file itself and the first two lines of the output so we can tell what permissions you need for that folder.
In the end, you'll have to chmod the permissions for the file or the folder or both in order to be able to edit the file.
PostPosted: Fri Jan 23, 2009 7:58 am
Granted you should have two accounts. Administrator and one other. But if you only have one account it has to be the administrator account. Why would the administrator not have permission to save a .config file? Be gentle, I'm not an expert, it just seems like the admin, who can theoretically do anything, should be able to save the file.
PostPosted: Fri Jan 23, 2009 8:16 am
That was my thought, that's why I'm asking.
I'm also getting the same message when I try to alter GRUB's menu.lst
by this, I'm assuming you mean to type that into a terminal window?
Using the GUI, I can right click, select properties, and the select the "permissions" tab.
It shows
Quote:
Owner: root
Acess: Read and Write
Group: root
Access Read Only
Others:
Access: Read Only
I'm guessing that the problem must be in that my name isn't root :lol:
Now that's on the file itself. If I take a step back in the directory the permissions on the folder itself say pretty much the same thing, just using different terms:
Quote:
Create and Delete Files
under owner, and
Quote:
Access Files
for the other two. :roll:
PostPosted: Fri Jan 23, 2009 8:27 am
Jip's right, but I'm not sure that doing a chmod on somewhere like /etc/X11 is a great idea, not to mention that a root account is setup on the machine, it's not exactly apparent though as it's setup by the OS.
You can enter superuser mode and make your edit that way. Since you're running Ubuntu, you can repeat your previous command with the command sudo in front of it so you run the command as temporarily as root.
so in your case, it'll be
sudo gedit /etc/X11/xorg.conf (substitute gedit with whatever editor you're using, be it pico, name, or whatever)
PostPosted: Fri Jan 23, 2009 8:30 am
Monkey Fed [PC]
Monkey Fed [PC]
I'm going to say that your install already HAS two accounts. You log onto Ubuntu with something like bbies1973 and a password, right? This is your user account. Some commands are not allowed by your user account, and like furball said, they need to be done with the SUDO command. I will also agree with furball in that you really shouldn't chmod xorg.conf.
Basically, if you try a command and it says you don't have permission, you need to do sudo (insert command here).
PostPosted: Fri Jan 23, 2009 8:33 am
how did you edit the file?
look up the sudo command. It is your friend. Two accounts are not necessary for Ubuntu.
PostPosted: Fri Jan 23, 2009 8:41 am
Monkey Fed [PC]
Monkey Fed [PC]
Are you sure? Every time I've installed Linux, you have an Administrator account (sudo) and a user account. You really don't want to be on your system full time as an administrator, do you?
Or do you mean two USER accounts?
PostPosted: Fri Jan 23, 2009 8:47 am
I should have been clear. There is almost certainly a root account on his box in addition to the user account. Generally, when you use the GUI install for a newer distro, you'll be prompted to create a user account as part of the setup. I'm guessing that this is the account that he is using.
By default, the user account created by the install routines is not a root account ... so he needs to use root to perform his administrative changes.
PostPosted: Fri Jan 23, 2009 8:48 am
:oops:
Nice catch, furball .. I wasn't looking at what he was editing.
PostPosted: Fri Jan 23, 2009 9:04 am
sudo pulls it's permissions from the group root, not the account.
The account root is a system user and is setup with the install. Ubuntu sets up the account like any other system user and basically assigns a random password to it.
In the end, you end up with 1 local user (whatever you setup) and about 20 systems users.
PostPosted: Fri Jan 23, 2009 9:08 am
Jipstyle wrote:
:oops:
I figure you were either distracted by the jeep, some french-canadian hottie, got a tattoo, or you're typing with one hand because you decided to use an axe again.
PostPosted: Fri Jan 23, 2009 9:12 am
I think I like this idea better than chmod, too.
This is exactly the answer I was looking for. Using sudo worked like a champ. Thanks.
PostPosted: Fri Jan 23, 2009 9:16 am
furball146 wrote:
Jipstyle wrote:
:oops:
See .. scary shit like this is exactly why I don't participate in 'who are you' threads ... you guys know too much about me as it is.
PostPosted: Fri Jan 23, 2009 9:18 am
;)[/quote] You are screwed royal now. lol
PostPosted: Fri Jan 23, 2009 10:15 am
You are screwed royal now. lol[/quote]
Time to move across the country yet again
Bastards.
PostPosted: Fri Jan 23, 2009 3:47 pm
Jipstyle wrote:
Bastards.
You take that back! My parents were married when I was born! :cry:
PostPosted: Fri Jan 23, 2009 4:55 pm
bbies1973 wrote:
Jipstyle wrote:
Bastards.
To each other?
PostPosted: Fri Jan 23, 2009 5:12 pm
Jipstyle wrote:
To each other?
or at least the milkman..
