It is currently Tue May 05, 2015 8:38 am
 Post subject: VIA VT7108s audio drivers for 8.10?
PostPosted: Wed Jan 14, 2009 8:09 pm
I cannot find them anywhere, not even on VIA's website. Does anyone know where I can find them? The onces I did find were for ubuntu 7.04 but they will not install
Thanks
PostPosted: Sun Jan 18, 2009 3:06 am
TravBv2.0
TravBv2.0
You don't usually download and install drivers in Linux like you would Windows. The drivers are actually modules built into the Linux kernel by low-level programs like ALSA or OSS (both of these are for your sound).
All you can really do is make sure you're running the latest version of ALSA or OSS, if you're audio chipset is supported. If it isn't, you're either gonna have to wait, bug the developers to code in some support, or write the code yourself.
PostPosted: Sun Jan 18, 2009 9:05 am
Is the AC97 not working?
or is there something specific you're trying to do...because normally there's additional things that need to be installed for mp3 and dvd playback.
