It is currently Mon Mar 30, 2015 5:01 am
 Post subject: Linux Media Servers
PostPosted: Sat Jan 10, 2009 8:30 pm
I was wondering if anybody has setup a Linux Media server and what program they use to stream media.
I have tried a couple of ones: ushare and fuppes. Ushare was easier to set up, but did not sort music very good. Fuppes wasn't as easy to set up, but does a better job at sorting music when taglib is installed. Both programs handled video files just fine. The only problem I have with fuppes is that it doesn't read the tag information from music files. You have to install taglib along with fuppes. Taglib normally doesn't support wma files, but there is a patch for this, but I have not been able to get taglib with the wma patch compiled. Anyway I use Ubuntu 8.10 server and fuppes to stream files to a xbox 360 and it works great, aside from my wma files not getting sorted properly.
Just wondering if any else uses linux and what program they use.
PostPosted: Sat Jan 10, 2009 9:37 pm
Million Club - 5 Plus*
I'm running coherence to stream to my 360. I'm using the FSStore though, so it's just a big pile of files, which works for me. I'm hoping to work with MediaStore as soon as axiom gets fixed for the new version of sqlite.
Elisa is supposed to be pretty good -- but I needed something that could run on a headless server.
