It is currently Mon Jan 26, 2015 6:32 pm
 Post subject: OpenSuse 11 video playback problems..
PostPosted: Fri Jan 09, 2009 12:09 pm
I don't really know where to post this,as it involves multiple areas..but here goes:
My OpenSuse 11 backup PC,using VLC 0.9.4,will not playback video files on DVDs. I've tried downloaded AVI copies of shows I have on disc(don't sue me),as well as regular DVDs. Nothing works.VLC keeps splitting the playback into X11 view seperate from the controls.(meaning I can't access the controls). What could possibly be the issue here?
PostPosted: Fri Jan 09, 2009 3:25 pm
Are you on 32 or 64 bit? Either way, I'll check in to it as I have 64-bit on my desktop and 32-bit on my laptop. Has it always done that?
PostPosted: Fri Jan 09, 2009 4:58 pm
OpenSuse 11 64-bit. And,no,this just started happening recently.
PostPosted: Fri Jan 09, 2009 5:07 pm
I assume you got the proper things you need from the one click downloads?
FWIW, I found that VLC doesn't seem to like pulseaudio, so I had to set VLC to use OSS rather then alsa or pulse. Once my sound worked correctly, my video in VLC started to work properly again.
I'll add that I believe that the libs (like libffmpeg0) you get from the VLC repository are buggy, so if you can get what you can from packman.
PostPosted: Fri Jan 09, 2009 5:34 pm
Also,the colors on DVDs are quite weird. They're shifted blue. Bizarrely,youtube videos play back fine. Could my DVD-ROM drive be dieing?
Which version of VLC should I try? (The one I have installed- 0.8.6,or the beta of VLC 1.0 for OpenSuse?)
