It is currently Fri Jan 30, 2015 10:42 am
 Post subject: RAID 5 under Ubuntu 8.10
PostPosted: Sun Dec 07, 2008 5:51 pm
Team Member Top 100
Team Member Top 100
I just installed Ubuntu 8.10 after Vista borked on me. I really like it so far, but I have a rather large problem. I have 5x 400GB hard drives in RAID 5 using my onboard Nforce7 raid controller. I cannot figure out for the life of me how to get them to show up as a single drive anywhere. Any help would be greatly appreciated.
eVGA 780i motherboard
q6600 @ 3.2Ghz
4 GB DDR800
eVGA 8800gt
PNY 6600 ? 256MB
Rosewill generic RAIDish controller for DVD burners
200GB SATA drive for OS
PostPosted: Mon Dec 08, 2008 3:21 am
TravBv2.0
TravBv2.0
I'm pretty sure your board supports hardware RAID, but not sure about RAID 5. If your baord does support it, then the problem could be that your MCP isn't fully supported by the Linux kernel, or it's that Linux's software RAID can't do RAID 5.
I would look into a RAID card that supports RAID 5 and works with Linux. 3ware and Areca make good RAID controllers.
PostPosted: Mon Dec 08, 2008 5:08 am
If it is hardware raid, it will show up as one disc, provided you created one volume on the array. I had a server running RAID 5 that I had ubuntu installed on.
The only difference is it was an actual server, which had a PER 5i SCSI controller card.
PostPosted: Mon Dec 08, 2008 8:18 am
Team Member Top 100
Team Member Top 100
The RAID is onboard. RAID 5 is an option. It shows up fine under XP and Vista without any drivers.
PostPosted: Mon Dec 08, 2008 9:22 am
I guess I'm puzzled as to how you set this up as I suspect this may end up being a which came first, the chicken or the egg or a cat chasing it's tail situation.
I'd believe you'd need to have a Raid enabled kernel to load, but the what you need resides in a Raid format that you can't access (at least until the module is loaded)
This may help you
http://www.linux-sxs.org/hardware/raid_for_idiots.html
although, it seems to be a post install solution and you're switching to LILO.
PostPosted: Mon Dec 08, 2008 11:23 am
Team Member Top 100
Team Member Top 100
I had vista on the computer, then I installed VMware and somewhere along the line it started locking up every night. Ubuntu is installed on a separate, single drive which is not in the array. I had RAID 5 set up fine before; it has all my data on it from movies and music to work documents. I installed Ubuntu so I woudn't have to worry about all the lockups and crashing. I always used linux for other appliances in my house, file servers, bittorrent boxes, firewalls/routers. I decided it was time to give it a shot in the big time. I really need to have my stuff in-tact and I can't re-create the array. My biggest problem here is the sage advice of every person who knows anything about computers: BACK UP! Well and often. Problem is, I don't have any other container large enough for all this stuff. So here I am. The vista/RAID chicken came before the Ubuntu/no raid egg.
PostPosted: Mon Dec 08, 2008 12:36 pm
So does ubuntu even boot and is it even showing in Vista anymore?
PostPosted: Mon Dec 08, 2008 12:50 pm
Team Member Top 100
Team Member Top 100
Ubuntu boots fine. I formatted the boot drive taking vista off and I put Ubuntu on in its place.
PostPosted: Mon Dec 08, 2008 12:58 pm
So you're not sure if the raid is intact still?
I guess I'm asking because you're saying you're seeing multiple drives and as pointed out earlier, it should show as one drive.
I suppose in a worst case, you could use something like dmraid to at least have the capacity to mount the drives.
PostPosted: Mon Dec 08, 2008 1:17 pm
Team Member Top 100
Team Member Top 100
I am reasonably sure the raid is still intact. I could probably delete it and add it back as I've done before. it's entirely possible that my motherboard raid is messed up as it wouldn't be the fist time that has happened.
