It is currently Sun Feb 01, 2015 5:24 am
 Post subject: is it possible???
PostPosted: Sat Nov 29, 2008 5:05 pm
Hey everyone,
I was going to build my own digital picture frame so i wanted to know if it is possible to lock out the keyboard so that way the slide show wont be disrupted by an accidental key press, and of course i would want to be able to unlock it by press a certain key combo. an example of what i want to do would be like the key gaurd on a cell phone. the distro i want to use is DSL
PostPosted: Sun Nov 30, 2008 8:24 am
You ... unplug the kb! :shock:
Plug it back in when you need to reconfigure something.
PostPosted: Sun Nov 30, 2008 6:49 pm
Ya i know that i was wondering if there was a fancy software based solution
PostPosted: Mon Dec 01, 2008 5:28 am
You could probably write something that captures all of the keyboard input and then does something when it detects a series of key presses.
PostPosted: Mon Dec 01, 2008 7:15 am
I'm sure that there are many ways to make this more complicated than it needs to be. ;)
