It is currently Fri Apr 24, 2015 5:07 pm
 Post subject: keeping driver and power consumption
PostPosted: Mon Nov 17, 2008 11:22 am
I am wondering if I upgrade to ubuntu 8.10 and had installed a driver that I made and installed in 8.04 will it still work in 8.10?
Has this happened to anyone else? I have my laptop dual booted(via wubi) and my ubuntu side seems to sip power as apposed to the vista side that gulps it. is this normal?
PostPosted: Mon Nov 17, 2008 3:47 pm
What kind of driver are you talking about?
My initial thought is you'd have to recompile it against a newer kernel and libraries
Not sure what to tell you about the power consumption. Maybe how the linux kernel deals with speedstep or powernow?
PostPosted: Mon Nov 17, 2008 8:59 pm
the linux driver madwifi. Although 8.10 supposedly has it, it doesn't work on my computer.
PostPosted: Tue Nov 18, 2008 7:01 am
Are you seeing any of the modules loaded?
PostPosted: Tue Nov 18, 2008 7:05 am
It will work fine.
