It is currently Fri Apr 17, 2015 10:04 pm
 Post subject: Ubuntu boot error
PostPosted: Thu Nov 13, 2008 1:32 pm
Hi, I just tried to boot into an ubuntu partition that I've installed. I have three hard drives, a 750 GB (storage), a 250 GB (Vista Ultimate), and an 160 GB (Linux OS and swap partition). I installed linux perfectly on that particular HDD, but hen I tried to boot up, the grub loader gives me either error 17 or 21. I tried supergrubdisk, but it still won't load. I have unplugged the OS and the storage dives, but that also doesn't work. What should I do?
PostPosted: Thu Nov 13, 2008 2:40 pm
list for us the hard drives, the order they show up in the bios, and the partitions on those drives (for a start)
PostPosted: Thu Nov 13, 2008 3:27 pm
This would probably be easier (and more accurate) by booting your LiveCD, go into a terminal session and typing in sudo /sbin/fdisk -l
I'll add, that since you've been fiddling with your HDs, I would highly recommend putting them back in the order they were before for fear you'll have issues with booting windows also.
PostPosted: Thu Nov 13, 2008 4:02 pm
In boot order=
WD 750 GB HDD (Storage)
WD 250 GB HDD (Vista)
WD 160 GB HDD (Ubuntu and Swap partition)
On the Unbuntu drive (150 GB Ubuntu; 10 GB Swap)
PostPosted: Thu Nov 20, 2008 12:56 pm
thats one hell of a swap file....I usually give mine like a gig.
Do your drives support the Cable Select setting??
Glenn Condrey
PostPosted: Thu Nov 20, 2008 1:09 pm
Anything more than 512-1024 MB on a typical user machine is a waste of space for swap area.
A server could possibly stand to use more... but not necessarily.
PostPosted: Thu Nov 20, 2008 1:10 pm
Reinstall grub?
http://ubuntuforums.org/showthread.php?t=224351
