It is currently Mon Apr 27, 2015 8:05 am
 Post subject: Distro installed via USB drive?
PostPosted: Sat Oct 25, 2008 2:19 am
Unfortunately I can't get my Gentoo install to work properly when I try linking the stage three tarball. I need to get an alternate OS running from which I can hopefully install Gentoo correctly.
EDIT: A little more info about my install issue
As far as I can tell, I'm experiencing a error caused by bad network configuring. Because I already partitioned my Windows install, I can't just boot back up and burn a ISO for another distro (Ubuntu or Knoppix comes to mind) so I'm a little stranded until I can get a working OS no matter how simple.
I guess essentially what I'm looking for is a distro that's install CD would be less then 128MBs. Any suggestions would be greatly appreciated as I've only got 3 weeks left to hit 70 before WotLK and I'm three levels and one working operating system away.
PostPosted: Sat Oct 25, 2008 8:48 am
team psycho or sumthin
Damn Small Linux?
PostPosted: Sat Oct 25, 2008 1:14 pm
I was looking at it but as I told the guys in Gentoo.irc the support for it looks, ironically, small. To be honest I'm not sure what version to even DL and put on the drive XD. I have to admit I'm a bit over my head with all this but I want it to work so badly, not to mention I'm really out of options with all my repair and diagnostic tools down in Illinois with my dad.
PostPosted: Sat Oct 25, 2008 2:40 pm
http://www.minix3.org/
Or how about just installing ubuntu onto a thumb drive?
http://www.pendrivelinux.com/2008/05/08 ... e-live-cd/
for a DSL thumb drive:
http://www.pendrivelinux.com/2007/01/02 ... e-usb-dsl/
DSL HD install:
http://www.damnsmalllinux.org/dsl-hd-install.html
And here is the ISO:
http://distro.ibiblio.org/pub/linux/dis ... -4.4.6.iso
PostPosted: Sat Oct 25, 2008 3:38 pm
Can't recommend this often enough: http://www.slax.org/
PostPosted: Sat Oct 25, 2008 3:49 pm
Only got a 128 meg drive yuri. It's sad I know >_<.
PostPosted: Sat Oct 25, 2008 4:06 pm
Team Member Top 1000
Go out and buy a 2 GB for about $15. It'll be worth it.
AJ
PostPosted: Sat Oct 25, 2008 4:20 pm
The burner on this lappy decided to start working randomly so I was able to burn th Slax ISO to a CD-RW. I'm doing the install right now so hopefully this will work. *fingers crossed*
PostPosted: Sat Oct 25, 2008 4:35 pm
*UPDATE*
Slax is installed and I'm already in love. I'm following the directions to installing Gentoo from another Linux OS from here:
http://www.gentoo.org/doc/en/altinstall.xml
PostPosted: Sat Oct 25, 2008 10:10 pm
Do to complications of installing Gentoo through another OS (mainly do to inexperience >_<) I'm just going to DL and burn the live CD. Since the original problem I posted this thread for is now moot, I'm just going to change the topic to "XoRns Struggle to Install Gentoo Properly". Maybe it will be a epic poem or a simple haiku, but it's getting installed one way or another. :evil:
PostPosted: Sun Oct 26, 2008 6:25 am
Haikus are easy
But sometimes they make no sense
Refrigerator
I remember installing gentoo 2 years ago on my HP laptop. Everything was going great. I fubar'd something and it didn't work.... reinstall. Then, like 60-70% through the install, the power cord came out and I didn't notice. It had a battery life of like 30 minutes doing anything but typing. Battery died, fubar'd the install. Start over...
Took me a good solid weekend to get it working. It was pretty slick when it did work though.
PostPosted: Mon Oct 27, 2008 12:12 am
Well, not only do I not have Gentoo installed on my PC, I also obliterated Windows on my fiancees laptop. Fortunatly, I had a single working iso burn of DSL so I can still wonder aimlessly with the slighest glimmer of hope in the fact that I still have access to the internet. Rignt now I'm trying to figure out how to install DSL to either my new 2 Gig (ya, I went and bought one, lol) or onto my harddive so I can free up my CD burner and install a more robust OS. The problem I'm encountering rightnow is gaining access to either my HD or USB dives with the terminal.
hdto=/dev/hda
doesn't seem to want to work. DMESG shows that my HD is detected (HDA1), but I can't find my USB key (SDA?).
Currently I'm looking for the directions to install DLS manualy to my HD. If I can access my CD drive I'll be able to burn ISO's again which should get me back to where I last left off (perhaps even better off since I won't be using a crappy laptop drive) trying to install Gentoo.
PostPosted: Mon Oct 27, 2008 3:08 am
By obliterate you mean?
There is no way for you to get a cd image of Ubuntu or something that has a good liveCD to fix it?
PostPosted: Mon Oct 27, 2008 12:18 pm
DSL run's fine on it, but Windows absolutly refuses to boot.
PostPosted: Mon Nov 10, 2008 9:04 pm
slaxers :lol:
