It is currently Sun Mar 29, 2015 5:29 am
 Post subject: NAS help...
PostPosted: Sun Oct 12, 2008 4:06 pm
Team Member Top 100
Team Member Top 100
I am looking at turning one of my PC's into a NAS, and I was wondering, I have a Gigabyte EP45-DS4P whch has 2x Gig-E ports, I was wondering, is there any way to get these to act as the same post, so I can essentially have 2Gigabits/sec? TYIA!
PostPosted: Tue Oct 14, 2008 11:35 am
It is possible, though you'd need the cabling to support that kind of traffic and you'd need a 2GB/sec pair of port on each end.
Why?
PostPosted: Tue Oct 14, 2008 11:52 am
Team Member Top 100
Team Member Top 100
I dunno, I am in that stage where I want MOAR!!! I am sure that regular Gig-E would be fine enough, just wondering... ;-)
PostPosted: Tue Oct 14, 2008 11:57 am
Yeah .. I'm sure you're not even close to saturating a gigabit connection.
OTOH, bigger better faster more. ;)
You CAN do it ... but you won't see a performance benefit. You would probably learn from it, though, and you'd have the fastest pair of connected PCs in the area.
Bear in mind that this would only be a point-to-point network ... you'd connect two PCs with a pair of GigE cables. Unless you have a router or switch capable of 2GB/sec? ;)
