It is currently Sat Apr 18, 2015 6:09 am
 Post subject: Help!Linux freezes!
PostPosted: Sat Oct 04, 2008 7:18 am
I am new to linux.When i enter to my Ubuntu installation(from the HDD),ubuntu freezes,and exactly the same with Fedora.But i tried mandriva installation and it's ok.Can anyone help me with that problem?
System:Asrock 775dual-880pro,p4 3.0 Ghz,asus 7300gs,ram 1gb(don't remember company),psu 350w(don't remember company)
PostPosted: Sat Oct 04, 2008 4:31 pm
Million Club - 5 Plus*
Can you say exactly what is on the screen when it freezes?
What versions of Ubuntu, Fedora and Mandriva are you using?
"it freezes" doesn't tell us anything at all.
PostPosted: Sat Oct 04, 2008 10:08 pm
TravBv2.0
TravBv2.0
I was going to as if you installed with Wubi, but you mentioned Fedora does the same thing.
Does it freeze when you use a particular programs, or particular set of programs? For instance, does it freeze when you use firefox and amarok, but it's fine when you use g-edit or kate?
Versions are definitely important when you're talking about Linux. Be as detailed as possible when asking about problems. Simply stating a problem is vague. It's ok though, we all learn sometime, right? Telling us about your hardware is good, but your exact brand of RAM and PSU aren't imperitive. Unless your hardware is having problems (which isn't the case since Mandriva is just fine), then your system seems more than fit to run Linux. My PII system runs Debian Etch without a hitch.
When you say Mandriva is fine, are you sure you're stressing it in the same way? Tell us as much as you can about the problem.
Oh and welcome to the forums :) We're a friendly bunch here...
PostPosted: Sun Oct 05, 2008 1:23 am
when i explore the menus it freezes in ubuntu,and in fedora freezes on the menu or during boots,i tried ubuntu 8.10 i remeber,fedora 7,mandriva 2008.
PostPosted: Sun Oct 05, 2008 1:25 am
oh and i forgot to say that i am a linux newbie
