It is currently Thu Jan 29, 2015 2:33 am
 Post subject: -noob- Installing Linux
PostPosted: Wed Sep 17, 2008 4:15 pm
I want to know how to install Linux an easy way. i have windows vista SP1. also i can just partition my hard drive but i don't know how do without deleting all my data. i am young thank you :)
PostPosted: Wed Sep 17, 2008 4:42 pm
Welcome to the forums however I regret to inform you that you posted in the wrong section and should message a mod to come move it for you.
Also, Linux has gotten tons easier nowadays to install. I would say the hardest thing for me was setting the primary boot partition when I was doing it custom through linux. :/
No Data will be lost just fyi.
PostPosted: Wed Sep 17, 2008 4:53 pm
yes i know i posted it in right place i am new :)
PostPosted: Wed Sep 17, 2008 7:49 pm
I indeed moved this thread so the Linux guys can better help you here.
PostPosted: Thu Sep 18, 2008 2:36 am
As I said in your other thread, which is now locked, read the stickies in this folder. They tell you everything that you need to know.
You can also try reading the docs that are provided by each distro. Ubuntu is very well known for their high quality docs .. start there.
PostPosted: Thu Sep 18, 2008 2:50 am
k thank you i looked at them but i am really new i really don't get it. please be a easier way to explain like 1. go into control panel 2. go into Administrate tools 3. go to computer management 4. click on disk management (thats as far as i know :D ) ( and as i said before i have vista)
PostPosted: Thu Sep 18, 2008 6:35 am
If you can't be bothered googling and learning, I don't think that linux is for you. However, if you want to try:
Read each of these links: https://help.ubuntu.com/8.04/newtoubuntu/C/index.html
If those are confusing, linux is not for you.
Next, https://help.ubuntu.com/8.04/switching/index.html
That link walks you through the differences between Windows and linux, what you need to know before you install linux, and finally HOW-TO install linux.
Those are all step-by-step instructions and explanations. It simply doesn't get any easier than that.
PostPosted: Thu Sep 18, 2008 1:36 pm
i installed Linux thanks for all your help so much :D it works fine by the way(smooth sailing installing).
PostPosted: Thu Sep 18, 2008 2:15 pm
also, is wine a installer for Linux, and how do i use and download it?
PostPosted: Thu Sep 18, 2008 5:20 pm
No, Wine is not an installer for linux.
Google 'linux wine'
PostPosted: Fri Sep 19, 2008 3:11 am
yeah thank you i downloaded it and i used it to install steam, i don't know how but it worked, also, maybe you know why i tried to chat on steam while in Linux but i didn't see anything come in chat box then i went on windows and asked the same guy if he read my messages before and he said no, also does steam games run ON Linux? :D
PostPosted: Fri Sep 19, 2008 8:48 am
http://www.google.com/search?hl=en&q=wi ... m&aq=f&oq=
PostPosted: Fri Sep 19, 2008 11:26 am
:D
