It is currently Thu Mar 26, 2015 7:58 pm
 Post subject: Router issues...RESOLVED!
PostPosted: Tue Sep 16, 2008 5:23 pm
Team Member Top 100
Team Member Top 100
I just switched my laptop from vista to ubuntu, and am getting a weird issue when i try to log into my router...
Router: D-Link DIR-655 @ 192.168.0.2
When I attempt to log in, it gives me this error:
'Permission denied to get property Element.nodeName
[Break on this error] if (xmlDataInstance.xmlDoc.firstChild.nodeName == 'parsererror') {
xml_data.js (line 133)'
Any idea what this is about? Or how to get around it? I log into my router quite often, so this is essential that I can get this to work...
TYIA for any help offered!
Last edited by nebbuchanezzar on Tue Sep 16, 2008 9:23 pm, edited 1 time in total.
PostPosted: Tue Sep 16, 2008 6:09 pm
Monkey Federation (Top 10)
Couple things.
Default IP for the D-Link routers is: 192.168.0.1 (not 2)
Is it connected directly via CAT cable computer <---> router?
When it was connected before, and worked, did you change any settings
that would prevent another computer from connecting?
PostPosted: Tue Sep 16, 2008 6:46 pm
Team Member Top 100
Team Member Top 100
DreadedOne509 wrote:
Couple things.
The default IP is indeed 192.168.0.1, tho I have had people decide to try to 'hack' my stuff, and this just is something else...Most the people around here are idiots, and wanna-be's, they don't know how to scan for stuff, and once I changed the IP to 0.2, most stuff stopped... ;-)
Also, I just tried doing a Remote connection to another Ubuntu 8.04 machine, and that machine connected fine...
EDIT: just checked, this machine now works fine as well...I just removed BugZilla, and I think once it didn't know there was a problem, it doesn't care... :-P so, in short, BugZilla doesn't seem to like my router...
