It is currently Sat Apr 18, 2015 9:58 pm
 Post subject: password changing on OpenSuse 11?
PostPosted: Sat Aug 23, 2008 11:53 pm
Does anyone know how to change a login password on OpenSuse 11without knowing the old password?
I forgot my old password,so I had to commit the mortal sin of Linux use-restart!!
Help!!
PostPosted: Sun Aug 24, 2008 5:31 am
Do you have root?
PostPosted: Sun Aug 24, 2008 6:48 am
Yes, login as root
If you forgot the password there, you're going to want to use your DVD (or a live CD if you have one) to get to a command prompt, mount the drive and perform a chroot on it to reset the root password...then reset your account via the root account.
This should steer you into how to perform that
http://www.5dollarwhitebox.org/wiki/ind ... t_Password
PostPosted: Sun Aug 24, 2008 8:55 am
Are you using grub? (Probably yes)
Here's the easiest way to do it. No LiveCD needed, or any of those extra mumb-jumbo commands.
  • Boot into single user mode. Simple instructions here.
  • Change the password:
    root@localhost:~# passwd username
  • Reboot*
    root@localhost:~# reboot
* There's absolutely no reason to use ctrl+alt+del when you can use the proper shutdown method
PostPosted: Sun Aug 24, 2008 5:55 pm
There is no reason not to map ctrl-alt-del to a proper shutdown command, either. :P
PostPosted: Sun Aug 24, 2008 7:08 pm
Bwahahaha! :lol:
PostPosted: Mon Aug 25, 2008 3:26 am
Monkey Federation (Top 10)*
Check the inittab, on many distros the ctrl+alt+del is mapped correctly.
ca::ctrlaltdel:/sbin/shutdown -t3 -r now
This was the default for CentOS and my installations of Fedora are very similar out of the box.
PostPosted: Mon Aug 25, 2008 6:56 am
No need to be subtle in this group, eh? :P
PostPosted: Mon Aug 25, 2008 12:33 pm
Ubuntu no longer uses the inittab file.. from what I've read, it sounds like it will still obey it if it's present, but it's not necessary. I'm not sure where to find that configuration outside that file. But I know it doesn't do a proper reboot.
I guess not :)
