It is currently Thu Jan 29, 2015 9:11 pm
 Post subject: USB gamepad... Linpus Lite (Acer Aspireone)
PostPosted: Fri Aug 15, 2008 8:05 pm
Hello long time member and almost as long time no poster :D
however not withstanding,
I received for my bday an acer aspireone... which has been going everywhere with me ... I LOVE this thing
however I have been slowly banging my way thru a couple things ... for the moment I am keeping the Linpus Lite that comes on it cause
a. it boots hella fast
b. Other options have a bunch of compromises of things that are not working correctly so far.
Acer apparently intended your average asiprone user to use what they preloaded and that is about it.. however not too hard to open the thing up to installing other things.
I have installed zsnes and it is running well except my usb game pad doesn't work
Finally the point... I could use some help getting the gamepad so if anyone is familiar w/ getting a usb gamepad (thrustmaster firestorm digital 2) up and running i would be obliged.
PostPosted: Tue Aug 19, 2008 12:29 am
Check kcontrol in the peripherals.. that's the easiest way. Let us know if it shows up there (if it does, it should be pretty obvious to you how to use it).
If that doesn't work, open a terminal and type this:
$ sudo lsusb
That'll tell you the device IDs of each USB item you have plugged in (this IS USB, right?). You can use this information to see whether anyone has written a driver for it.
PostPosted: Wed Aug 20, 2008 8:54 pm
$ sudo lsusb
so the Aspireone is running a modified (OEM) version of Linpus you have to do a "hack" to even get access to the more advanced features / and half of that stuff doesn't work as acer did some "strange" (??) things blah blah blah
the point is there is no kcontrol nor comparable place in settings to configure the game pad.
sudo lsusb
shows
bus 002 Device 003: ID 07b5: 9903 Mega World International, Ltd
for the game pad
according to this
http://www.qbik.ch/usb/devices/showdev.php?id=1042
just a generic HID driver should work??
PostPosted: Thu Aug 21, 2008 6:40 pm
sudo lsusb
shows
for the game pad
according to this
Want my advice? Ditch the OS. It sounds like a piece of crap. Put Ubuntu on it, and it'll be recognized automatically. There's no point in mucking around with all this, unless you really like something about that distribution.
PostPosted: Fri Aug 22, 2008 12:19 am
sudo lsusb
shows
for the game pad
according to this
ah... see here is the RUB...
a. it boots (usable network up ..etc) in under 1/2 minute (which is pretty awesome)
b. ATM ubuntu has a few problems on the aspire one (no hibernate support ...and the sound is f'd up apparently)
however yeah... the linpus is kinda ticking me off... hopefully in the near future there should be some nice Aspireone remix available (i'm actually hoping for a fully sorted PCLinuxOS remix personally).
