It is currently Mon Apr 27, 2015 4:03 am
Post new topic Reply to topic  [ 19 posts ]
 Post subject: NDIS Wrapper
PostPosted: Fri Aug 15, 2008 7:35 am
I am having some trouble with my wireless driver, I have attempted to install the ndis wrapper but it didn't work does any one have any suggestions? I am using centosplus with the KDE interface.
PostPosted: Fri Aug 15, 2008 8:08 am
Network card?
PostPosted: Fri Aug 15, 2008 8:14 am
I just remember she posted about it before:
Digital.Girl wrote:
Hi Everyone,
I have sucsessfully installed linux on my laptop but I need to find some drivers for my intel4964 wireless card.
I wasn't able to find much about an Intel 4964, but I know that the 3945 pro wireless was common, and works well with (at least ubuntu) Linux out of the box.
Intel WiFi driver info, maybe?
PostPosted: Fri Aug 15, 2008 8:55 am
I have tried the driver and it didn't work so I heard about the NDIS wrapper and decided to try that. well I am not sure how to install it. It appears that the config is missing when I ran the ls command. I am confused.
PostPosted: Fri Aug 15, 2008 9:27 am
team psycho or sumthin
One of the few things I can say without a doubt about *nix is; pay very close attention to the case, space and format of the commands you enter.
PostPosted: Fri Aug 15, 2008 9:32 am
I copied and pasted from the install file to the konsole.
PostPosted: Fri Aug 15, 2008 9:36 am
Monkey Federation (Top 10)
Are you getting anything back from the console like an error or any messages when you try to install?
PostPosted: Fri Aug 15, 2008 9:45 am
You need a recent kernel, at least 2.6.16, with header files for the
kernel. Make sure there is a link to the kernel source from the modules
directory. The command
ls /lib/modules/`uname -r`/build
should have at least 'include' directory and '.config' file.
There is no config when I run this command but there is an include.
then:
Download the latest version of the ndiswrapper sources from here and
extract it with the command
tar zxvf ndiswrapper-version.tar.gz
tar: ndiswrapper-version.tar.gz: Cannot open: No such file or directory
tar: Error is not recoverable: exiting now
tar: Child returned status 2
tar: Error exit delayed from previous errors
PostPosted: Fri Aug 15, 2008 10:00 am
You need to specify the version of your ndiswrapper.
The italicized portion of this command needs to be altered to fit the name of the file that you downloaded:
PostPosted: Fri Aug 15, 2008 10:45 am
tar zxvf ndiswrapper-1.53.tar.gz comes back with the same error message.
PostPosted: Fri Aug 15, 2008 12:11 pm
You need to find that file. The error says the file doesn't exist ... why?
PostPosted: Fri Aug 15, 2008 2:37 pm
Million Club - 5 Plus*
I have a feeling that it's the iwl4965 driver that's needed. (I have that card, and it works great with iwlwifi)
What is the output of
lspci
and
iwconfig
PostPosted: Fri Aug 15, 2008 4:30 pm
command not found on both commands. And I did copy and paste so there is no typo
PostPosted: Fri Aug 15, 2008 5:35 pm
Are you running these commands as root or su?
PostPosted: Sat Aug 16, 2008 8:08 am
I'm running a 4965 and had no problems..
PostPosted: Sun Aug 17, 2008 8:34 am
Jipstyle Wrote:
I first type in sudo su and that brings me to root@....#
PostPosted: Sun Aug 17, 2008 6:09 pm
FYI, "sudo -i" works the same as "sudo su"
From there, what is the output of lspci and iwconfig?
PostPosted: Wed Aug 27, 2008 6:50 pm
It says that it can't find the command. I believe this system is very stable, and I enjoy it much more than windows. It just seems like I am having trouble installing things. I have tried a couple of items from kdelook.org and I am having the same issue. I am certain that it has everything to do with me not knowing the commands. Any suggestions are appreciated. thanks!
PostPosted: Wed Aug 27, 2008 7:14 pm
Plug your computer sans ethernet and let some1 remote desktop to you :D lol jk jk
