It is currently Wed May 22, 2013 9:01 am
 Post subject: help with konsole commands [alias]
PostPosted: Thu Apr 03, 2008 2:18 am
Team Member Top 100
Team Member Top 100
i setup a new folder today, and it is weird, the ~/ folder is locked with root priv. only, and i havent quite learned ubuntu well enough to remember the stuff for changing priv's...what i need help with is, i want to get an alias command setup so when i type
alias fah
it will do a 2 part command:
cd ~/FAH
sudo ./FAH504-Linux.exe -forceasm -advmethods -verbosity 9
is this possible? if so, how? and also, is there something easier to do? i remember that you can get FAH set to run at boot, but forgot how...whatever it takes to make sure this will be as easy as possible to run for the person whos pc it is...doesnt matter how hard it is for me [tho i am n00b...h3ar m3 r0ar!!!]
also, say i got an alias setup to be run w/o the sudo i there, could i then run
sudo alias fah
would that work as well as having the sudo embedded in the alias command?
ty in advance for any help offered...
PostPosted: Thu Apr 03, 2008 1:01 pm
Million Club - 5 Plus*
You could start by creating a quick script like this:
cat > ~/runfah.sh << EOF
#!/bin/bash
cd ~/FAH
EOF
chmod +x ~/runfah.sh
alias fah ~/runfah.sh
You would then run it with:
fah
However, the alias will only stick for the length of the terminal session.
The similar way to do it (if you rebooted after using the alias) would be to run:
~/runfah.sh
PostPosted: Wed Apr 09, 2008 7:08 am
Monkey Federation (Top 10)
Just curious, why are you running fah with sudo?
 Post subject: Re: help with konsole commands [alias]
PostPosted: Thu Apr 10, 2008 1:44 am
Team Member Top 100
Team Member Top 100
for some reason the home folder needs root priv. to be modified, and i couldnt get F@H to keep a config file, it kept looping, and i figured it just wasnt making one, so i ran it with sudo and it worked fine...
