It is currently Sun Jan 25, 2015 12:23 pm
 Post subject: FreeBSD Security Advisory FreeBSD-SA-04:17.procfs
PostPosted: Thu Dec 02, 2004 6:50 am
In the lab!
In the lab!
FreeBSD-SA-04:17.procfs Security Advisory
The FreeBSD Project
Topic: Kernel memory disclosure in procfs and linprocfs
Category: core
Module: sys
Announced: 2004-12-01
Credits: Bryan Fulton, Ted Unangst, and the SWAT analysis tool
Coverity, Inc.
Affects: All FreeBSD releases
Corrected: 2004-12-01 21:33:35 UTC (RELENG_5, 5.3-STABLE)
2004-12-01 21:34:23 UTC (RELENG_5_3, 5.3-RELEASE-p2)
2004-12-01 21:34:43 UTC (RELENG_5_2, 5.2.1-RELEASE-p13)
2004-12-01 21:33:57 UTC (RELENG_4, 4.10-STABLE)
2004-12-01 21:35:10 UTC (RELENG_4_10, 4.10-RELEASE-p5)
2004-12-01 21:35:57 UTC (RELENG_4_8, 4.8-RELEASE-p27)
CVE Name: CAN-2004-1066
For general information regarding FreeBSD Security Advisories,
including descriptions of the fields above, security branches, and the
following sections, please visit
<URL:http://KILLMEPLEASE.org/security/>.
I. Background
The process file system, procfs(5), implements a view of the system
process table inside the file system. It is normally mounted on
/proc, and is required for the complete operation of programs such as
ps(1) and w(1).
The Linux process file system, linprocfs(5), emulates a subset of
Linux's process file system and is required for the complete operation
of some Linux binaries.
II. Problem Description
The implementation of the /proc/curproc/cmdline pseudofile in the procfs(5)
file system on FreeBSD 4.x and 5.x, and of the /proc/self/cmdline
pseudofile in the linprocfs(5) file system on FreeBSD 5.x reads a process'
argument vector from the process address space. During this operation,
a pointer was dereferenced directly without the necessary validation
steps being performed.
III. Impact
A malicious local user could perform a local denial of service attack by
causing a system panic; or he could read parts of kernel memory. Such
memory might contain sensitive information, such as portions of the file
cache or terminal buffers. This information might be directly useful, or
it might be leveraged to obtain elevated privileges in some way. For
example, a terminal buffer might contain a user-entered password.
FreeBSD 4.x does not implement the /proc/self/cmdline pseudofile in
its linprocfs(5) file system, and is therefore only affected if the
procfs(5) file system is mounted.
In its default configuration, FreeBSD 5.x does not utilize procfs(5)
or linprocfs(5) and will therefore be unaffected by this vulnerability
unless the configuration is changed.
IV. Workaround
Unmount the procfs and linprocfs file systems if they are mounted.
Execute the following command as root:
umount -A -t procfs,linprocfs
Also, remove or comment out any lines in fstab(5) that reference
`procfs' or `linprocfs', so that they will not be re-mounted at next
reboot.
V. Solution
Perform one of the following:
1) Upgrade your vulnerable system to 4-STABLE or 5-STABLE, or to the
RELENG_5_3, RELENG_5_2, RELENG_4_10, or RELENG_4_8 security branch dated
after the correction date.
2) To patch your present system:
The following patches have been verified to apply to FreeBSD 4.8, 4.10,
5.2, and 5.3 systems.
a) Download the relevant patch from the location below, and verify the
detached PGP signature using your PGP utility.
[FreeBSD 4.x]
# fetch ftp://ftp.FreeBSD.org/pub/FreeBSD/CERT/ ... cfs4.patch
# fetch ftp://ftp.FreeBSD.org/pub/FreeBSD/CERT/ ... .patch.asc
[FreeBSD 5.x]
# fetch ftp://ftp.FreeBSD.org/pub/FreeBSD/CERT/ ... cfs5.patch
b) Apply the patch.
# cd /usr/src
# patch < /path/to/patch
c) Recompile your kernel as described in
<URL:http://KILLMEPLEASE.org/handbook/kernelconfig.html> and reboot the
system.
VI. Correction details
The following list contains the revision numbers of each file that was
corrected in FreeBSD.
Branch Revision
Path
RELENG_4
src/sys/miscfs/procfs/procfs_status.c 1.20.2.6
RELENG_4_10
src/UPDATING 1.73.2.90.2.6
src/sys/conf/newvers.sh 1.44.2.34.2.7
src/sys/miscfs/procfs/procfs_status.c 1.20.2.5.4.1
RELENG_4_8
src/UPDATING 1.73.2.80.2.30
src/sys/conf/newvers.sh 1.44.2.29.2.28
src/sys/miscfs/procfs/procfs_status.c 1.20.2.4.8.2
RELENG_5
src/sys/compat/linprocfs/linprocfs.c 1.84.2.1
src/sys/fs/procfs/procfs_status.c 1.52.2.1
RELENG_5_3
src/UPDATING 1.342.2.13.2.5
src/sys/compat/linprocfs/linprocfs.c 1.84.4.1
src/sys/conf/newvers.sh 1.62.2.15.2.7
src/sys/fs/procfs/procfs_status.c 1.52.4.1
RELENG_5_2
src/UPDATING 1.282.2.21
src/sys/compat/linprocfs/linprocfs.c 1.78.2.1
src/sys/conf/newvers.sh 1.56.2.20
src/sys/fs/procfs/procfs_status.c 1.49.2.1
PostPosted: Thu Dec 02, 2004 6:58 am
Thanks, Dex! :)
PostPosted: Thu Dec 02, 2004 1:12 pm
In the lab!
In the lab!
always glad to spread the security warnings... :)
I should do it in windows parlor... but then I'd have to make 10 posts a day! :twisted:
