It is currently Sun Apr 19, 2015 5:09 pm
 Post subject: things to do in linux
PostPosted: Wed Dec 01, 2004 12:35 am
I have been dabaling with linux for quite some time now, i can install software, recomplie my kernal and all that, even install gentoo (from a stage 3 tarball).
So basiclly i am looking for software that will hold my intrest in linux (basicly when i sit down what machine do i use linux or windows 2000) and things to do to make KDE feel more like home, what kindof things can i do to make KDE my own, Links and stuff would be great
Thanks
Nick
PostPosted: Wed Dec 01, 2004 6:48 am
Check the 'linux links' sticky, and try reading some of the threads that ask 'should I use linux' or 'why linux' ... also try the 'linux questionaire' thread, since it asks members to list the software that they commonly use.
 Post subject: Re: things to do in linux
PostPosted: Thu Dec 02, 2004 11:43 am
Check out KDE-look and KDE-apps to customize KDE.
PostPosted: Fri Dec 03, 2004 4:22 pm
Thanks for the help
how do you install those KDE modifcations, there are some i would like to try but can no seem to get them installed
PostPosted: Sat Dec 04, 2004 2:34 am
nick0danger wrote:
Thanks for the help
That depends, what are you trying to install?
PostPosted: Sat Dec 04, 2004 3:46 pm
http://kde-look.org/content/show.php?content=16114
http://kde-look.org/content/show.php?content=1529
Not sure how install these ones, i did make the ones that have an RPMS and it works.
