It is currently Sun Apr 26, 2015 12:10 pm
 Post subject: Ubutu
PostPosted: Mon Nov 29, 2004 2:18 pm
Team Member/ Ex-Team Member/ Team Member
Ok I have this installed, where can I get a firewall and antivirus if needed. Also where can I download other software that is compatable. Rookie here so any easy to follow instruction for installing apps would help a ton. Thanks
 Post subject: Re: Ubutu
PostPosted: Mon Nov 29, 2004 3:06 pm
Firestarter is a great firewall tool.
This is Linux, you don't need antivirus/defrag/registry cleaner/antispyware software like other high maintenance operating systems.
I don't know specifically about Ubuntu, it looks like it is .deb based so I assume it uses apt-get. Check the Linux Links sticky at the top of this forum for sources of software.
PostPosted: Mon Nov 29, 2004 3:43 pm
As Skesis stated, Ubuntu is Debian based and uses Apt as it's package manager.
In order to install packages using apt, you have to be root. Instead of logging on as Root, you use the sudo command. As an example, say you wanted to install the latest kernel for an AthlonXP based system.
apt-cache search linux K7
The latest according to my install, is 2.6.8.1. The filename that comes up is:
linux-image-2.6.8.1-3-k7
So, you would type this to install it:
sudo -u root apt-get install linux-image-2.6.8.1-3-k7
Then, you would enter your login password to authenticate, then it installs it. I'll be able to help a little more when I get home.
PostPosted: Mon Nov 29, 2004 3:57 pm
Thanks I'll work at it some and get back with questions after all my hair is pulled out.
